How does one permanently turn off any and all system "recording" of used apps, directories, or files in Ubuntu 12.10?
I specifically DO NOT want a list of my recently used files showing up in my menu for anyone who may be looking over my shoulder to see. I have tried turning off everything in the "privacy app", and I have also told the app NOT to record activity from specific directories, files, and applications and I still see that my system is recording recently used files.
Any help on how to permanently turn off the recently used file list would be very appreciated. I do not merely want to prevent the recently used files from being displayed in the menu, I also want to make sure the system is not keeping any record of recently used files, directories, or applications anywhere on the system. I would like to be able to do this from the privacy app, as that's what it implies it's supposed to do anyway, but obviously doesn't.
jokerdino
  • 41,732
Jason
  • 457
This worked for me on manjaro cinnamon, disabled Recent Files
http://www.webupd8.org/2012/12/nautilus-36-how-to-clear-recent-files.html
To clear the Nautilus "Recent" files, you need to remove the "~/.local/share/recently-used.xbel" file - to do this from the command line, copy/paste the command below in a terminal:
rm ~/.local/share/recently-used.xbel
To permanently disable any recent files from showing up in the Nautilus Recent sidebar item, open the "~/.config/gtk-3.0/settings.ini" file with a text editor:
gedit ~/.config/gtk-3.0/settings.ini
and under "[Settings]", add the following lines:
gtk-recent-files-max-age=0
gtk-recent-files-limit=0
If this file does not exist, create it. Make sure the header says "[Settings]" and not "Settings". This is how the file should look after editing it:
[Settings]
(there can be other items below these, of course).
To apply the changes, log out and log back in or follow the steps under "Clear the Nautilus Recent Files list" above.
rubo77
  • 34,024
  • 52
  • 172
  • 299
Toppy
Go to System Settings > Privacy and select All from drop down menu in Forget Activity section and click on Delete history. If you turned off recording you wont see any more recent files.However Music and Video and Files lens will show your songs and videos collection from home directory. You can remove particular lens by
sudo apt-get purge unity-lens-video
shsh
  • 313
You don't say exactly what desktop (DE) you're concerned about, but the file ~/.local/share/recently-used.xbel seems to be common to several DE's.
You could cause any writes to it to be "thrown out" by linking it to /dev/null :
  1. First remove it with
  2. Then (symbolic) link to /dev/null with
    ln -vs /dev/null ~/.local/share/recently-used.xbel
Now, any writes to ~/.local/share/recently-used.xbel will essentially be lost, and reading the file will return nothing.
Xen2050
  • 8,943
