I'm running Ubuntu on my Samsung ARM Chromebook in chroot via crouton. I'm trying to run Cisco AnyConnect VPN in Ubuntu and ran into an issue. It installs but the daemon won't start. I found a description of the issue here: https://github.com/dnschneid/crouton/issues/15
So I found the shell script for AnyConnect in /etc/init.d but I'm not smart enough to figure out how to run these commands manually. I'm hoping someone can point me in the right direction.
Here are the contents of the vpnagentd_init file:
#!/bin/sh
# chkconfig: 345 85 25
# description: vpnagentd is used for managing the cisco vpn client datapath.
# processname: vpnagentd
# Source function library.
if [ -e "/etc/init.d/functions" ]; then
  . /etc/init.d/functions
fi
RETVAL=0
start() {
  # If TUN isn't supported by the kernel, try loading the module...
  /sbin/lsmod | grep tun > /dev/null
  if [ $? -ne 0 ]; then
    /sbin/modprobe tun > /dev/null 2> /dev/null
      # check for /dev/net/tun
      [ -c "/dev/net/tun" ] || echo  Warning: Unable to verify that the tun/tap driver is loaded.  Contact your system administrator for assistance.
    fi
  fi
  echo -n $"Starting up Cisco VPN daemon "
  /opt/cisco/vpn/bin/vpnagentd
  RETVAL=$?
  echo
  return $RETVAL
stop() {
  echo -n $"Shutting down Cisco VPN daemon "
  killall vpnagentd
  RETVAL=$?
  echo
  return $RETVAL
dostatus() {
  status vpnagentd
restart() {
  stop
  start
# See how we were called.
case "$1" in
  start)
        start
  stop)
        stop
  restart)
    restart
  status)
        dostatus
        echo $"Usage: vpnagent {start|stop|restart|status}"
        exit 1
esac
exit $RETVAL
Splendor
  • 113
As an example, to run the 'start daemon' section, copy the contents of the file between "start(){" and "}" and put it in a text file startScript (as ane example). Use chmod+x startScript to make the script executable, then use ./startScript to run it. The same can be done for the stop and status sections if desired.
Nerdfest
  • 4,658
I'll try to answer if it is just to run a shell script.
Open terminal Ctrl + Alt + T and type :
sudo nautilus
Give your password. Browse to location where that script present. Right click on the file. Goto properties--> Permissions. Give execute permissions by checking on "Allow executing file as a program".
Use cd directory_name to go to script location. And type sh vpnagentd_init.sh to run the script. Hope it will help.
hg8
  • 13,582
learner
  • 591
