10
If you visit a project on Launchpad, you can see all active branches of all developers involved in the project.
Is there a bzr command to do the same without visiting the project's page on Launchpad in a browser?
janos
  • 4,968
I don't know of any bzr command that does this, but it's actually very easy to script using the Launchpad python API. For instance:
#!/usr/bin/env python
import os, sys
from launchpadlib.launchpad import Launchpad
cachedir = os.path.expanduser("~/.launchpadlib/cache/")
launchpad = Launchpad.login_anonymously('find_branches',
                                        'production',
                                        cachedir)
try:
    project = launchpad.projects[sys.argv[1]]
    for b in project.getBranches():
        if b.lifecycle_status not in ["Abandoned", "Merged"]:
            print b.bzr_identity
except KeyError:
    print "Project unknown... \nUsage: " + sys.argv[0] + " lp_project_name"
So with python find_branches.py deluge we get:
lp:deluge
lp:~vcs-imports/deluge/trunk
lp:~mvoncken/deluge/ajax-template-dev
lp:~deluge-team/deluge/master
lp:~shaohao/deluge/0.9
lp:~damoxc/deluge/master
You can run wild with it and do things like sort by date_created, date_last_modified, or create your own heuristic for what branches are interesting to you. See:
https://launchpad.net/+apidoc/1.0.html#branch
kynan
  • 2,235
Bazaar is a version control system no more then that, completely separate project from Launchpad.
It is possible to parse directly the project branches HTML page or its Atom news feed.
  1. Declare a shell function:
    lslp() {
        wget -q -O - http://feeds.launchpad.net/$1/branches.atom | xml2 | grep "/feed/entry/title=" | cut -c 19-;
    • wget -q -O - http://feeds.launchpad.net/projectname/branches.atom
      get branches news feed (Atom xml)
    • xml2
      convert XML document to a flat format
    • grep "/feed/entry/title="
      filter out lines with "/feed/entry/title=", XML nodes that contain branch name
    • cut -c 19-
      remove "/feed/entry/title=" from result lines.
  2. Example:
    $ lslp deluge
    lp:deluge
user.dz
  • 49,176
