How do I record the live streaming screen with audio? I read in some forums about Mplayer and VLC player. I tried using download helper, with no luck
These are the steps I do
  1. http://shalomtv.tv
  2. Click and play shalom India, the first tab, live television
Braiam
  • 69,112
Suresh
  • 277
The stream in your link seems to be a RTMP stream. Solution:
Downloading RTMP streams with rtmpdump and rtmpsrv
  1. Install rtmpdump by opening your terminal with Ctrl + Alt + T and using this command:
    sudo apt-get install rtmpdump
  2. Redirect RTMP traffic through a local port. Copy & paste this command to the terminal window:
    sudo iptables -t nat -A OUTPUT -p tcp --dport 1935 -j REDIRECT
  3. Start rtmpsrv by typing in the terminal:
    rtmpsrv
  4. Go to the website where the video stream is and start playing the video.
  5. After a while, rtmpsrv should output a longish command that will look something like this:
    rtmpdump -r "rtmp://livestream.someaddress.com/live/" -a "live/" -f "LNX 11,6,602,171" -W "https://www.someaddress.org/live/player.swf" -p "http://live.tv/" -y "nnnnnn.sdp" -o nnnnnn.flv
  6. Stop rtmpsrv with Ctrl + C. You can leave the website.
  7. Before downloading, you need to delete the port forwarding you did previously. Copy & paste this command to the terminal:
    sudo iptables -t nat -D OUTPUT -p tcp --dport 1935 -j REDIRECT
  8. Finally, copy the longish command starting with "rtmpdump -r..." and paste it in the terminal. rtmpdump should start downloading the stream. You can stop the downloading with Ctrl + C.
pileofrocks
  • 1,352
  • 26
I guess this is newish, but this thing is brilliant: youtube-dl-bdmurray.youtube-dl It's a "snap", so to install it you type
sudo snap install youtube-dl-bdmurray
Then I simply wrote youtube-dl-bdmurray.youtube-dl [url-containing-video]
on the command line, and it found the video, started the video (which was not automatic), downloaded/streamed the thing, and left me with a perfect mp4 file.
CPBL
  • 848
