I have a couple of game-pads with a USB interface, The game-pads are RockFire QF-501UV, When connecting them to the USB port I get the following message:
Feb 27 22:32:55 localhost kernel: [97408.112022] usb 5-1: new low-speed USB device number 28 using uhci_hcd
Feb 27 22:32:55 localhost kernel: [97408.232024] usb 5-1: device descriptor read/64, error -71
Feb 27 22:32:55 localhost kernel: [97408.456033] usb 5-1: device descriptor read/64, error -71
Feb 27 22:32:55 localhost kernel: [97408.672024] usb 5-1: new low-speed USB device number 29 using uhci_hcd
Feb 27 22:32:56 localhost kernel: [97408.792020] usb 5-1: device descriptor read/64, error -71
Feb 27 22:32:56 localhost kernel: [97409.016018] usb 5-1: device descriptor read/64, error -71
Feb 27 22:32:56 localhost kernel: [97409.232039] usb 5-1: new low-speed USB device number 30 using uhci_hcd
Feb 27 22:32:56 localhost kernel: [97409.640020] usb 5-1: device not accepting address 30, error -71
Feb 27 22:32:57 localhost kernel: [97409.752024] usb 5-1: new low-speed USB device number 31 using uhci_hcd
Feb 27 22:32:57 localhost kernel: [97410.160020] usb 5-1: device not accepting address 31, error -71
Feb 27 22:32:57 localhost kernel: [97410.160038] hub 5-0:1.0: unable to enumerate USB device on port 1
Googling I've found some people had similar (but not the same) issues with USB devices, some suggested solutions which did not work for me. I've tried the followings and it didn't work (same messages):
echo -1 > /sys/module/usbcore/parameters/autosuspend
echo Y > /sys/module/usbcore/parameters/use_both_schemes
echo -n 0000\:00\:1d.7 > /sys/bus/pci/drivers/ehci_hcd/unbind
where (before executing the last command):
# ls /sys/bus/pci/drivers/ehci_hcd
0000:00:1d.7 bind module new_id remove_id uevent unbind
all as root and after every command I've checked to see if there is any difference.
Linux doesn't even recognize the USB which attached
# lsusb
Bus 005 Device 023: ID 046d:c52e Logitech, Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Linux 3.5.0-25-generic #38-Ubuntu SMP i686 i686 i686 GNU/Linux
