I have a Lenovo IdeaPad Yoga. It's been working flawlessly with Windows 8 - 9 hour battery life, awesome touchscreen, 4-second boot times.
So obviously I wanted to try Ubuntu 12.10. Well, I downloaded it and installed it - but I couldn't change the brightness!
These hotkeys work in Windows but not in Ubuntu - and none of the solutions others have proposed in other similar questions with Lenovo laptops have worked.
How can I make my brightness hotkeys work?
Jorge Castro
  • 73,717
FOR 12.10
Okay, I found an answer in this page.
This solved my brightness problems permanently:
sudo gedit /etc/default/grub
You will find this line in the new opened window:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Change it to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Save and close the window and type this in the terminal:
sudo update-grub
and reboot.
FOR 13.04
  1. Add the acpi_backlight=vendor to your grub default command line
  2. Run the update-grub command
  3. blacklist the ideapad_laptop by adding "blacklist ideapad_laptop" to your /etc/modprobe.d/blacklist.conf file.
  4. Reboot
I have another solution:
GRUB_CMDLINE_LINUX="acpi_osi=\"!Windows 2012\""
and
sudo update-grub
fixed it for me.
cebor
  • 185
Another solution for my Lenovo G480:
  1. sudo nano /etc/default/grub
  2. Change the line GRUB_CMDLINE_LINUX="quiet splash" into:
    GRUB_CMDLINE_LINUX="quiet splash acpi_osi=Linux"
  3. sudo update-grub
  4. Restart your Linux
This fix should work for another Lenovo models.
Maxwel Leite
  • 2,424
