16
I have a fresh Ubuntu 12.04 VM, and I would like to install Ruby 2.0.0-p0. I am able to get Ruby installed easily enough, but I am unable to get gems to work.
$ gem install bundler
ERROR:  Loading command: install (LoadError)
cannot load such file -- openssl
ERROR:  While executing gem ... (NoMethodError)
    undefined method `invoke_with_build_args' for nil:NilClass
I have open SSL installed, so I'm not exactly sure what the problem is.
$ sudo apt-get install libssl1.0.0 libssl-dev
Reading package lists... Done
Building dependency tree
libssl-dev is already the newest version.
libssl1.0.0 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Similarly,
$ which openssl
/usr/bin/openssl
If I go back to the installation, there are two lines that concern me.
$ sudo make install
Failed to configure openssl. It will not be installed.
Failed to configure readline. It will not be installed.
Thanks!
In your source location, cd ext/openssl and then ruby extconf.rb. This will generate a makefile in the ext/openssl directory. Simply make && sudo make install it to build the ruby openssl extension, and install the .so into the appropriate location.
Ditto ext/readline for readline support.
Then you should be able to make ruby properly.
Edit: in case I wasn't clear enough:
pushd ext/openssl
ruby extconf.rb
popd
pushd ext/readline
ruby extconf.rb
popd
make
sudo make install
Matty K
  • 201
I ran into the same issue, I had to install the following two packages
libssl-dev
libreadline-dev
in fact I found I had to install the following packages to get ruby 2.0.0 and postgres 9.2 to compile on ubuntu 13.04 with openssl and readline so I thought I would share them
sudo apt-get -y update
sudo apt-get install -y make g++
sudo apt-get install -y curl git-core python-software-properties
sudo apt-get install -y build-essential zlib1g-dev libyaml-dev libssl-dev
sudo apt-get install -y libgdbm-dev libreadline6-dev libncurses5-dev
sudo apt-get install -y libpq-dev libffi-dev
Chris D
  • 71
for me it was a case of missing dependencies.
i thought i had all the dependencies required to install ruby, but i too was getting an openSSL and readline error.
i attempted to install ruby with RVM without root privileges which failed but gave me a list of missing dependencies. i then installed the dependencies with a package manager. i then re-attempted to install ruby from source from the beginning, and everything worked OK
the dependencies that were missing, for me, were:
patch libyaml-devel autoconf gcc-c++ readline-devel libffi-devel openssl-devel automake libtool bison sqlite-devel
but they may be different for you.
update: i don't originally remember where exactly i found this list, but a quick search found similar lists on the following pages, which might also help you:
https://www.digitalocean.com/community/tutorials/how-to-install-ruby-on-rails-on-centos-6-with-rvm
http://www.itzgeek.com/how-tos/linux/ubuntu-how-tos/install-ruby-on-rails-on-centos-ubuntu-fedora-from-source.html
When installing ruby 2.0, it is possible that rubygems 2.0 installation did not complete ok, because of openssl. Make sure you provide a valid path to the openssl config file; you could:
find . -type f -name "openssl.cnf"
path is usually $HOME/.rvm/usr or $HOME/.rvm/usr/ssl
Then
[sudo] rvm reinstall ruby-2.0.0-p0 --with-openssl-dir=[openssl.cnf path] --verify-downloads 1
Make sure rubygems installation complete successfully. Might be a better way to fix that path without reinstalling, but this should do it.
