There is a file named RESULTS.txt and I want to open this file in my terminal. (I mean I want to see the file contents be displayed in the terminal and not in some text editor)
How do I do that ?
How do I do that ?
For short files:
cat <path/your_file>
directly shows a text file in the terminal.
For longer files:
less <path/your_file>
lets you scroll and search (/ text to search Enter) in the file; press q to exit.
e.g.
cat /home/john/RESULTS.txt
less /home/john/RESULTS.txt
Another alternative is vim.
vim RESULTS.txt
Once you opened a file with vim you can insert text by typing i, for instance. If you want to save your file use :w (write) or :q (quit) or :wq (for write and quit) or :q! (quit and do not save). Sometimes you need to hit the ESC key to be able to type the commands.
Vim requires some learning, but is widely used and it is very versatile.
Check the community help wiki: https://help.ubuntu.com/community/VimHowto
Vim is an advanced text editor that provides the power of the de-facto Unix editor 'Vi' with a more complete feature set. Vim is often called a "programmer's editor," and is so useful for programming that many consider it an entire IDE. It's not just for programmers, though. Vim is perfect for all kinds of text editing, from composing email to editing configuration files.
all those are best ways and there is one more way to do this & that’s with head command.
head -n -1 filename.txt
and
head -n -0 filename.txt
both will give you the same input.
Head command Explanation:
Generally head command used to print the starting lines of the any text file.we can view the text file with
head filename.txt
That will prints the 1st 10 lines of the above text file.
If you want to specific on the number of lines which are to be view then you can use head as
head -n 20 filename.txt
Then in the above text file first 20 lines will be viewed.
If you want to view whole file data with head means then then we can get it by
Hope that above explanation will give you some idea on usage of head.
If the file is rather long, you might want to use
less RESULTS.txt
so that you can navigate through it with directional keys.
Another option is:
tail -n 30 result.txt
to print out the last 30 lines of a large file named result.txt.
Another option:
tail -f your_file
It will show you the last ten lines of your_file. If a process appends something to this file, you see it on your terminal. man tail gives you more on tail.
It's useful to see what happens with a server when you use this command on a log file.
Press Ctrl-C to quit when you are done viewing.
There are a lot of alternatives for doing that:
Some of these programs have a lot of parameters, so check that out with --help after the command..
cat filename prints the whole file at oncemore/less filename similar behaviour for see the file in partstail filename start reading from the tail of the filegrep text filename for filtering resultsHope that some of this works for you..
The shell programm sed also has an option to print out the contents of a file.
sed -n p RESULTS.txt
So sed walks through every line and prints it to the terminal. But sed also has editing capabilities. For instance if you want to replace each comma with a dot you can write:
sed 's/,/./g' RESULTS.txt
As we seem to be listing all available alternatives of displaying any text file in the terminal, it would be quite fun to introduce pv as technically one valid (but unusual) method, although I would normally use cat instead for most things.
It is in the repositories and so can be installed with sudo apt-get install pv if you don't have it already.
As the man page notes, pv is very often used to
monitor the progress of data through a pipe...pv will copy each supplied FILE in turn to standard output (- means standard input), or if no FILEs are specified just standard input is copied. This is the same behaviour as cat(1).
With pv you can literally print the file to the screen, and choose the rate (-L) at which it appears. The example below uses a high rate (300), but if you choose a low rate such as -L 50, it will appear as if the computer is typing out the file for you.
pv /etc/apt/sources.list -qL 300
Needless to say you can increase the rate further (-L 8000), and the command becomes very similar to cat, with the output appearing instantaneously.
For more information see man pv or the Ubuntu manpages online.
Why not.
You can also use
most RESULTS.txt
It's almost the same as less, but it also supports horizontal scrolling if the file contains long lines - which is really handy.
most is not installed by default, so to use it, you have to first
sudo apt install most
If you just want to read the file content, go in the file directory and type
less RESULTS.txt
If you want to read and edit the text file, from the same directory type
nano RESULTS.txt
The -w switch in the nano command can be inserted before the file name to prevent wrapping of long lines.
Lots of good options provided here already, but another option if you need to edit is emacs:
emacs -nw RESULTS.txt
might not need the -nw, depending. You may also have to apt-get install emacs23 or apt-get install emacs24, or if you don't have X or don't want related X dependencies, apt-get install emacs23-nox or apt-get install emacs24-nox.
And in addition to cat and less as mentioned elsewhere, there is more. More is less, because you see a page at a time and can't scroll via the command itself, but you can scroll with the terminal window, if you have a scrolling terminal window:
more RESULTS.txt
If you're in bash, you have something similar to cat by doing:
while IFS= read a;do echo "$a";done<RESULTS.txt
Another more exotic answer is to use grep:
grep . RESULTS.txt
The grep command searches for a every character in the file and prints it out. So basically the complete file is printed out.
