I am trying to add a new tab to the tabs component with the code below.
When running there is no error reported but no additional tabs are show. I have tried using both tabs and tabs.__tabsModel as the parent but no additional tabs are show.
import QtQuick 2.0
import QtQuick.LocalStorage 2.0
import Ubuntu.Components 0.1
MainView {
// objectName for functional testing purposes (autopilot-qt5)
objectName: "mainView"
applicationName: "news-feed"
width: units.gu(100)
height: units.gu(75)
Tabs {
anchors.fill: parent
Component.onCompleted: {
mainView.initializeDB();
mainView.saveFeed("BBC News","http://feeds.bbci.co.uk/news/rss.xml");
mainView.saveFeed("Jono Bacon","http://www.jonobacon.org/?feed=rss2");
mainView.saveFeed("The Register", "http://www.theregister.co.uk/headlines.atom");
fillTabs();
tools: ToolbarActions {
Action {
objectName: "action"
iconSource: Qt.resolvedUrl("avatar.png")
text: i18n.tr("Tap me!")
onTriggered: {
label.text = i18n.tr("Toolbar tapped")
// First tab begins here
Tab {
objectName: "tabFrontPage"
title: i18n.tr("Front Page")
// Tab content begins here
page: Page {
Column {
anchors.centerIn: parent
Label {
text: i18n.tr("This will be the front page \n An aggregation of the top stories from each feed")
function fillTabs() {
var db = getDatabase();
db.transaction(function(tx) {
var rs = tx.executeSql('SELECT * FROM feeds;');
if (rs.rows.length > 0) {
for(var i = 0; i < rs.rows.length; i++) {
var feedTab = Qt.createQmlObject('import QtQuick 2.0;import Ubuntu.Components 0.1;Tab {anchors.fill: parent;objectName: "Tab";title: i18n.tr("Tab");page: Page {anchors.margins: units.gu(2);Column {anchors.centerIn: parent;Label {id: label;objectName: "label";text: i18n.tr("Tab");}}}}',tabs,"feedTab");
} else {
res = "Unknown";
//Storage API
function getDatabase() {
return LocalStorage.openDatabaseSync("news-feed","1.0","StorageDatabase",10000)
//Initialise DB tables if not already existing
function initializeDB() {
//Create settings table if not existing
tx.executeSql('CREATE TABLE IF NOT EXISTS settings(setting TEXT UNIQUE, value TEXT)');
tx.executeSql('CREATE TABLE IF NOT EXISTS feeds(feedName TEXT UNIQUE, feedURL TEXT UNIQUE)')
//Write setting to DB
function setSetting(setting,value){
//setting: string - setting name (key)
//value: string - value
var res = "";
var rs = tx.executeSql('INSERT OR REPLACE INTO settings VALUES (?,?);',[setting,value]);
//console.log(rs.rowsAffected)
if(rs.rowsAffected > 0) {
res = "OK";
} else {
res = "Error";
return res;
//Read setting from DB
function getSetting(setting) {
var res="";
var rs = tx.executeSql('SELECT value FROM settings WHERE setting=?;', [setting]);
res = rs.rows.item(0).value;
} else {
res = "Unknown";
return res;
function saveFeed(feedName, feedURL) {
var res = "";
db.transaction(function(tx){
var rs = tx.executeSql('INSERT OR REPLACE INTO feeds VALUES (?,?)',[feedName,feedURL]);
if (rs.rowsAffected > 0) {
res = "OK";
} else {
res = "Error";
return res;
//Return a single feed
function getFeed(feedName) {
var res = "";
var rs = tx.executeSql('SELECT feedURL FROM feeds WHERE feedName=?;', [feedName]);
res = rs.rows.item(0).feedURL;
} else {
res = "Unknown";
return res;
//Return all feeds and urls
function getFeeds() {
var res = "";
return rs;
} else {
res = "Unknown";
return res;
