Is there a way to disable per-package updates? I love Clementine, but the 1.1 version removed a crucial feature. I'd like to stick with the 1.0 version installed via a downloaded .deb package.
Can I somehow disable updates for it, or do I have to check the update manager every time? The updated version is in the base sources of Ubuntu, so I can't just remove a PPA.
mreq
  • 4,932
You can always run your updates and select what to install or what not. So when you see an update for Clementine simply deselect the update in the update-manager, and you'll come out fine.
The downside is that you'll have to deselect it each time you run your updates.
This is the easiest way.
