Apache cannot fully determine domain name when I tried restarting after install.
I get this error;
$ sudo /etc/init.d/apache2 restart
Restarting web server config apache2
apache2: Could not reliably determine the server's fully qualified domain
name, using 127.0.1.1 for ServerName.
Why am I seeing 127.0.1.1? I have tried saving ServerName localhost into my /etc/init.d/apache2 but it keeps redirecting me to Google search page every time I type phpmyadmin.
Will appreciate any expert help.
Zanna
  • 72,312
frqcuse
  • 69
Unless there is a specific reason you need it to determine it there is no real reason to try and do so. I run 3 soon to be 5 sites on my server and at every restart it still says that. It seems to only be important in very specific cases.
Line:
should be added to /etc/apache2/httpd.conf or to some specific site in /etc/apache2/sites-available/. The configuration can vary on different versions but httpd.conf should be there always.
Aditya
  • 13,616
Kride
  • 101
As default the configurations of apache is blank. Try to set with this.
Open terminal, and edit /etc/apache2/httpd.conf ,
set Servername localhost
Besure u have changed httpd.conf with right.
Restart with this command :
sudo service apache2 stop
sudo service apache2 start
See image below.
Baim
  • 245
You need to specify ( Optional ) name of the site in apache configuration. Edit /etc/apache2/httpd.conf file.
Add following parameter
Servername <your-website-name>
For example
 Servername ketan.in
Restart apache
KK Patel
  • 19,753
