I want to uninstall java 7 and install the version 6 (as some of programs I would like to use are incompatible with 7).
I tried :
$ sudo apt-get remove openjdk-7-jre
[sudo] password for USER:
Reading package lists... Done
Building dependency tree
 libatk-wrapper-java-jni : Depends: libatk-wrapper-java (>= 0.30.4-0ubuntu4) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
$ sudo dpkg -r openjdk-7-jre
dpkg: dependency problems prevent removal of openjdk-7-jre:amd64:
 default-jre depends on openjdk-7-jre (>= 7~u3-2.1).
 icedtea-7-plugin:amd64 depends on openjdk-7-jre.
 icedtea-netx:amd64 depends on openjdk-6-jre (>= 6b23~pre10~) | openjdk-7-jre; however:
  Package openjdk-6-jre is not installed.
  Package openjdk-7-jre:amd64 is to be removed.
 openjdk-7-jdk:amd64 depends on openjdk-7-jre (= 7u15-2.3.7-0ubuntu1~12.10).
dpkg: error processing openjdk-7-jre:amd64 (--remove):
 dependency problems - not removing
 openjdk-7-jre:amd64
$ dpkg -l | grep icedtea
ii  icedtea-7-jre-jamvm:amd64                 7u15-2.3.7-0ubuntu1~12.10                  amd64        Alternative JVM for OpenJDK, using JamVM
ii  icedtea-7-plugin:amd64                    1.3-1ubuntu1.1                             amd64        web browser plugin based on OpenJDK and IcedTea to execute Java applets
ii  icedtea-netx:amd64                        1.3-1ubuntu1.1                             amd64        NetX - implementation of the Java Network Launching Protocol (JNLP)
ii  icedtea-netx-common                       1.3-1ubuntu1.1                             all          NetX - implementation of the Java Network Launching Protocol (JNLP)
monkey@ICANSEEYOU:~$ dpkg -l | grep jre
ii  default-jre                               1:1.7-43ubuntu3                            amd64        Standard Java or Java compatible Runtime
ii  default-jre-headless                      1:1.7-43ubuntu3                            amd64        Standard Java or Java compatible Runtime (headless)
ri  openjdk-7-jre:amd64                       7u15-2.3.7-0ubuntu1~12.10                  amd64        OpenJDK Java runtime, using Hotspot JIT
ii  openjdk-7-jre-headless:amd64              7u15-2.3.7-0ubuntu1~12.10                  amd64        OpenJDK Java runtime, using Hotspot JIT (headless)
ii  openjdk-7-jre-lib                         7u15-2.3.7-0ubuntu1~12.10                  all          OpenJDK Java runtime (architecture independent libraries)
Patryk
  • 9,416
Before removing oracle java you must choose another implementation to provide java. Do so with sudo update-alternatives --config java
Then you should be able to remove it. Or you can leave it as it shouldn't be used at that point.
I suppose you are using 12.10 or 13.04. Here default-jre depends on openjdk-7-jre. So you can't remove openjdk-7 without removing also default-jre and break a lot of other dependencies.
But it is no problem to install openjdk-6 beneath openjdk-7.
You can now try to configure the problematic application to use the right jdk or change the default jre with the update-alternatives command. Here is a little helper for this task:
 function updateDefaultJava() {
    local pkgArch
    case $(arch) in
        x86_64) pkgArch=amd64;;
        i686)   pkgArch=i386;;
        *)      echo "unhandled architecture $(arch)"; return 1;;
    esac
    local javaBase=/usr/lib/jvm/java-6-openjdk-${pkgArch}
    local cmd
    for cmd in jre/bin/java jre/bin/javaws
    do
        local c=$(basename ${cmd})
        update-alternatives --set ${c} ${javaBase}/${cmd}    || let retC+=$?
        done
    done
    exit ${retC}
 updateDefaultJava
