I have been using windows remote desktop from remmina, what i feel so awkward is I don't see the save password button enabled, I need to frequently use my remote connection, and don't like entering username, passwords, etc, everytime...
Help me..
Had the same problem, discovered that there is a bug using snap. Removed the snap and reinstalled from Remmina repository for Ubuntu. Also made sure the permissions were set on ~/.remmina. Works fine now. This is on Xubuntu 16.10. Seems that others have also noted that the issue relates to Xubuntu.
sudo snap remove remmina
Get repo details from Remmina site.
sudo apt install remmina
Open Remmina, then go to the Preferences (under three bars), then change Remmina data folder to your username.
Also make sure you own the .remmina folder (and all its contents).
$ ls -l --directory ~/.remmina/
Your user name should appear on the ls record like:
drwx------ 2 username username 4096 Jan 1 12:15 /home/username/.remmina
If root owns this file, You can correct the permissions like:
# chown --reference ~/ --recursive ~/.remmina/
Notes:
# Implies "run as root" (eg with sudo), as only root may change ownership of files.--reference ~/ Tells chown to copy the ownership of ~/, which bash expands before the command gets executed, and points to your home folder.You need to save your connection, total connection not only your password.
