I have BCM4313 wi-fi module, which works ok under open-source brcmsmac module, except for numerous disconnects and sudden breakdowns.
So I've downloaded the proprietary tarball, installed it, but can't say it made any impact.
When I remove all the open-source modules by using
rmmod brcmsmac bcma
and then plug all the proprietary ones by
modprobe lib80211 cfg80211
insmod /lib/modules/my_kernel/drivers/net/wireless/wl.ko
nothing happens, I mean my Wicd app doesn't detect any available connections.
I'm not an expert at Linux by any means, so I wonder what might be an adequate solution.
ps. dmesg |grep wl output:
[ 5801.356381] wlan0: deauthenticating from b8:a3:86:42:93:cb by local choice (reason=3)
[ 5801.455680] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5804.419696] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5804.935700] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5806.994247] wlan0: authenticate with b8:a3:86:42:93:cb
[ 5806.994328] wlan0: send auth to b8:a3:86:42:93:cb (try 1/3)
[ 5806.995904] wlan0: authenticated
[ 5806.998173] wlan0: associate with b8:a3:86:42:93:cb (try 1/3)
[ 5807.001231] wlan0: RX AssocResp from b8:a3:86:42:93:cb (capab=0x401 status=0 aid=5)
[ 5807.001804] wlan0: associated
[ 5807.002284] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 5827.490902] wlan0: deauthenticating from b8:a3:86:42:93:cb by local choice (reason=3)
[ 5827.558074] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5828.108186] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5830.138468] wlan0: authenticate with b8:a3:86:42:93:cb
[ 5830.138583] wlan0: send auth to b8:a3:86:42:93:cb (try 1/3)
[ 5830.140406] wlan0: authenticated
[ 5830.142840] wlan0: associate with b8:a3:86:42:93:cb (try 1/3)
[ 5830.148274] wlan0: RX AssocResp from b8:a3:86:42:93:cb (capab=0x401 status=0 aid=5)
[ 5830.148856] wlan0: associated
[ 5830.150317] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
sudo modprobe wl & dmesg |grep wl:
[10392.295126] wlan0: deauthenticating from b8:a3:86:42:93:cb by local choice (reason=3)
[10392.392534] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[10392.947547] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[10404.291431] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[10404.933929] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[10406.963425] wlan0: authenticate with b8:a3:86:42:93:cb
[10406.963531] wlan0: send auth to b8:a3:86:42:93:cb (try 1/3)
[10406.965115] wlan0: authenticated
[10406.967018] wlan0: associate with b8:a3:86:42:93:cb (try 1/3)
[10406.975538] wlan0: RX AssocResp from b8:a3:86:42:93:cb (capab=0x401 status=0 aid=3)
[10406.976099] wlan0: associated
[10406.976817] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[13533.369462] wl: module license 'MIXED/Proprietary' taints kernel.
an ouptut of lsmod | grep -e brcmsmac -e b43 -e bcma while my default module is loaded:
brcmsmac              531848  0
mac80211              539908  1 brcmsmac
bcma                   35656  1 brcmsmac
brcmutil               14755  1 brcmsmac
cfg80211              206566  2 brcmsmac,mac80211
cordic                 12535  1 brcmsmac
my connection was working great since the problem I originally adressed was resolved.
however, today I've made a reboot just to find out that my connection doesn't work again.
first of all, I've loaded the wl module by using
sudo modprobe wl
after that checked ifconfig and saw that eth1 inetrface is down and executed
sudo ifconfig eth1 up
to bring it up
shortly afterwards used iwconfig to make sure that eth1 is properly detected
in the end typed
sudo iwlist eth1 scan
to find all the available networks, which worked just as planned
however, when I've finally decided to connect and used for it
sudo iwconfig eth1 essid Network_name  (no key option here since this it's not set)
the failure kicked in, since no connection is being established and iwconfig shows that no access point is associated with eth1 interface.
I've read a bunch of manuals but still have no idea what I need to do in order to get my internet back.
The re-installation of bcmwl-kernel-source is supposed to blacklist the less good driver brcmsmac and obviously didn't. Please open a terminal and do:
gksudo gedit /etc/modules
If brcmsmac, bcma or b43 are in there, remove them. Add wl. Proofread, save and close gedit. Now do:
gksudo gedit /etc/modprobe.d/blacklist.conf
At the end, add the following lines:
blacklist brcmsmac
blacklist bcma
blacklist b43
Proofread, save and close gedit. Reboot. Check:
iwconfig
Is your wireless interface now eth1? Is your connection now working as expected?
chili555
  • 61,330
I assume you mean 14e4:4727, not 4272 as above. If so, I believe bcmwl-kernel-source is correct for your device, not brcmsmac. Let's try to get it installed correctly.
sudo apt-get install linux-headers-generic
sudo apt-get install --reinstall bcmwl-kernel-source
If all goes without error, then do:
sudo modprobe wl
Any errors or warnings? Your wireless should now be working properly.
chili555
  • 61,330
