On Lenovo T400 and Ubuntu 10.10, I am using CPU Frequency Scaling Monitor 2.30.0 on the panel to show and control CPU frequency.
My CPU frequency by default will change according to load. But I want to make CPU work at the lowest level and so I choose 800 MHz in CPU Frequency Scaling Monitor. After a few seconds, however, it automatically changes back to Powersave or Performance mode which has automatic adjustment to CPU frequency.
I was wondering how to actually make CPU work at the lowest level? Thanks!
PS: On Acer Aspire 5000 and ubuntu 8.10, I can use CPU Frequency Scaling Monitor to control CPU frequency as I wish.
muru
  • 207,228
Tim
  • 26,107
Follow the steps:
sudo apt-get install rcconf
sudo rcconf
Search for
ondemand
option and disable(un-check the check-box) it using space-bar.
jrg
  • 61,707
Ilias
  • 1,326
man cpufreq-set. Quick answer:
sudo cpufreq-set -r -d MINIMUM-FREQUENCY -u MAXIMUM-FREQUENCY
You might try the exact command:
sudo cpufreq-set -r -d 800MHz -u 1GHz
karel
  • 122,292
  • 133
  • 301
  • 332
