When I fist start Nautilus I invariably open five favourite tabs..
I've tried multiple URIs from the command line, but it opened multiple windows.
Is it possible to somehow do this via command-line ?...
It is still unsupported by Nautilus itself, however you can use a script that admits several parameters to reuse or open a new instance of Nautilus if not running.
In order to use this solution you'll need to install pachages wmctrl and xclip. You can do it installing wmctrl and xclip using the Software Center (click on the links) or via Terminal with sudo apt-get install wmctrl xclip.
Create a new file nautab.sh and add the following code:
#!/bin/bash
# Nautilus opens folders in new tabs
# Dependencies: sudo apt-get install wmctrl xclip
# Pass directories as parameters, i.e. nautab /opt /var/log /usr/local/etc
# Wrong parameters will be shown as invalid directories
if [ "$(wmctrl -xl | grep "nautilus.Nautilus")" == "" ]; then
# wmctrl reports Nautilus not running
if [[ -d $1 ]]; then
nautilus "$1" &
else
>&2 echo Not a directory: $1
nautilus &
fi
shift
# Nautilus takes some time to become responsive to automation
sleep 2
fi
#Save old clipboard value
oldclip="$(xclip -o -sel clip)"
for folder in "$@"
if [ -d "$folder" ]; then
echo -n $folder | xclip -i -sel clip
wmctrl -xF -R nautilus.Nautilus && xdotool key --delay 120 ctrl+t ctrl+l ctrl+v Return
# Use this if you suspect funny clipboard behaviour
#xclip -verbose -o -sel clip
#Leave some time before opening a new tab
sleep 0.5
else
>&2 echo Not a directory: $folder
fi
#Restore old clipboard value
echo -n "$oldclip" | xclip -i -sel clip
This code is based is based on an answer to other question.
Runnautab [directory]... and new tabs will open on it. Note that there will be some delay; this is in order to wait for Nautilus to be responsive. Feel free to play with numbers.
As per jorge's comment, the answer is "no"...
So as a side issue, because it's not a current option in Nautilus, I've cobbled together a script.. It suits me, given the situation.
I initially had some timing inssues which caused modifier-key states to go whacko, so I've added 100ms delays between steps, and it is now behaving itself on my system...
This may need to be changed in a different environment...
Here it is; at paste.ubuntu.com
