I'm following the instructions at How do I create a completely unattended install of Ubuntu? to create an unattended install. This will be installed on a VM, so I would like to disable swap.
If I just create the kickstart file without any mention of swap, after completing the file system step, it stalls on a screen asking whether I'm sure I want to continue without swap and I have to confirm this.
Is there any way to disable swap in the method I'm using? If not, is there a different recommended method for unattended installs ?
Thanks,
Ubuntu (tested):
preseed --owner partman-basicfilesystems partman-basicfilesystems/no_swap boolean false
For more details see: http://tech.mariusb.com/2009/programming/debian-preseed-with-no-swap.html
Seth
  • 59,332
