When installing Ubuntu from a LiveCD on a Windows system, the following options are available:
  • Install Ubuntu alongside Windows XP/Vista/7/8
  • Replace Windows with Ubuntu
  • Other
Is "Install Ubuntu alongside Windows" the same as Wubi or is it a real dual boot?
EDIT: I seem to have caused some confusion, I am not asking what the difference is between a Wubi install and a regular dual-boot install, I am asking if the "Install Ubuntu alongside Windows" option creates a Wubi install or a regular dual-boot one.
jobukkit
  • 5,266
It is a real dual boot ;) you need to free up a partition and if you want to use swap, then you need to create a swap partition too ;)
Mostafa Shahverdy
  • 5,342
  • 22
  • 34
My understanding is that a wubi install creates a file in a windows partition and then boots from that. If you wiped windows you might lose this file.
When you install alongside windows, you're really installing it as its own, completely independent OS. You could remove the windows partition and ubuntu would be unaffected.
kleinric
  • 333
