I want to install Steam for Linux. As I have only 256gb SSD and not enough space for games, I'd like to install it (and all it's games) to a USB3 flash drive.
How to do that? Preferably using sudo apt-get install ****. Haven't find a way to specify the installation location.
mreq
  • 4,932
I think the major problem is the size of the games and not the size of Steam.
Install Steam as usual on your SSD. The Games are installed in ~/Steam/SteamApps/common/TITLE
Backup the "common"-Folder and delete it. Then make a symlink to your USB-Drive like this:
ln -s /media/<usb-drive>/steamgames/common ~/Steam/SteamApps/common
Now the games should be installed on your USB-Drive. I don't really know if it works, but you can give it a try.
mikewhatever
  • 33,013
prophecy201
  • 2,760
  • 17
  • 22
Inexact duplicate of How do I use a different drive as an installation location for Steam?
It is not in general possible to change the install paths used by apt-get.
However, in this case, the Steam .deb package only installs a few bootstrap scripts. Subsequently running the Steam script actually downloads the application, which subsequently manages its own updates.
While as far as I know Steam doesn't offer you a choice of location at install time (it will go into $HOME/.local/share/Steam), you can subsequently move the install location or create additional libraries - see the answer above.
chronitis
  • 12,647
