-1
I installed ubuntu onto a usb drive, but now the problem i face is that the computer doesn't boot without the USB inserted. It goes to grub rescue. I also have ubuntu installed on a partition on my hardisk (after installing it on the usb), i would like to direct the stage 1 grub to the stage to 2 on that. I'm pretty confused, and don't know much about ubuntu, so please excuse my lack of knowledge.
Flute
Ow, this is a mess (lol) !
I'd suggest (I read that it doesn't concern a dualboot with Windows, or am I wrong on this? )
you follow the steps to take:
  • make a bootable USB-stick with an Ubuntu-ISO of your wish (12.04.2 is a good option since it has for about 5 years support) ; you can do that on Windows or Ubuntu (startup disc -tool)
  • Boot this USB-stick; an Ubuntu-logo should show followed with an option to try Ubuntu or Install Ubuntu
  • Make a good working internet-connection (you can do that with wireless or cabled)
  • Select install Ubuntu on the hard-drive (USB works but it's slow in respons; using Ubuntu on a hard disk is by far out the better option, unless you need a stick for travelling around. )
  • follow the onscreen options and select 'use the entire disk' (mind you: if you have WIndows on your hard disk you should select Ubuntu side by side with Windows)
  • Let the installer run and proceed with required info asked by the installer.
  • When everything is finished , reboot and voila you have Ubuntu.
For having Ubuntu on a portable USB-drive, I'd suggest you make a new question here and we'll guide you all the way.
I hope this will lead you further, and if you click here you'll have more information.
