I have a question concerning Intel Turbo Boost and the ability to disable it in Ubuntu 12.04. I wanted to disable Turbo Boost because it produced a lot of heat and I didn't find a need for it in Ubuntu (being so lightweight as it is compared to Windows). I found that by installing msr-tools and running modprobe msr and then:
wrmsr -p(PROCESSOR) 0x1a0 0x4000850089
Where PROCESSOR is the number of my CPU core allowed me to shut off Turbo Boost for that core. After appending msr into my etc/modules and the wrmsr lines into my rc.local I found I was able to shut off Turbo Boost at boot.
My question is: Is this method I've used safely disabling Turbo Boost, or should I attempt to find a different workaround.
I have an MSI-GE60 with no setting in the BIOS for Turbo Boost, so changing it like this appeared to be the only way.
Thanks to anyone who can help.
You could set the max CPU frequencies to a setting just under the turbo boost - attached is the code I use in rc.local
echo 1 > /sys/module/processor/parameters/ignore_ppc
for x in /sys/devices/system/cpu/cpu[0-3]/cpufreq/;do
  echo 2501000 > $x/scaling_max_freq
done
In my system the speed of 250100 is a turbo speed, non-turbo being 2500000
Charles Green
Charles Green
  • 21,859
You can also disable boost by setting /sys/devices/system/cpu/cpufreq/boost to 0.
Jonas Malaco
  • 1,453
  • 13
  • 15
For example, to disable turbo over 69 degrees you can crontab every 1 minute:
echo $[`cat /sys/devices/platform/coretemp.0/hwmon/hwmon0/temp1_input`/69000] > /sys/devices/system/cpu/intel_pstate/no_turbo
-1
You most probably have to do it through the BIOS - at least, that is how it was for me. Otherwise, you could install indicator-cpufreq (sudo apt-get install indicator-cpufreq) and set it to a setting that doesn't use Turbo, like conservative. You can even set it to a constant speed (mine is usually at 1.2), and change it when you find things getting slow. I would also recommend Hardware Sensors Indicator:
 sudo add-apt-repository ppa:alexmurray/indicator-sensors
 sudo apt-get update
 sudo apt-get install indicator-sensors
To monitor your temperature and make sure it's not going to high.
notablytipsy
  • 2,927
