Without going into unnecessary detail, I purchased a laptop with Win8 pre-installed, spent a couple days troubleshooting/learning how to get Ubuntu 12.10 to load up from both a flash drive and a DVD-R.
I can boot to the GRUB2 screen, but either choice of trying to install Ubuntu or loading it without install sends me to blank/black screen. The bits I've found from other threads has pointed to this possibly not having an Ubuntu-specific driver installed for my graphics card.
Here is what I need to install: http://www2.ati.com/drivers/linux/amd-driver-installer-catalyst-13.1-linux-x86.x86_64.zip
The problem is that this unzips to a .RUN file...
How do I install a .RUN file from within Windows 8? Any ideas? I'm new at this so I might be behind on some of the technical jargon... will try my best. Any help is much appreciated.
don.joey
  • 29,392
You really can not install that driver into the live session. You need to first install Ubuntu, then install the driver from the command line.
If you can not install from the desktop CD, you may have to use the Alternate CD. The alternate CD has a more robust installer.
BUT ... you really do not need to manually install the driver at all. Just install Ubuntu , then install the driver from the repositories.
Save a backup copy of xorg.conf in case this doesn't work.
sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.BAK
Remove/purge current fglrx and fglrx-amdcccle (If you have used a method outside of aptitude, apt, Software Center or Synaptic, follow the other party's instructions for removal):
sudo apt-get remove --purge fglrx fglrx-amdcccle
For some users, the fglrx-updates and fglrx-amdcccle-updates packages do not work. If you attempted to install them, also do:
sudo apt-get remove --purge fglrx-updates fglrx-amdcccle-updates
Reboot.
Install the driver:
sudo apt-get install fglrx fglrx-amdcccle
Generate a fresh xorg.conf BEFORE REBOOTING!
sudo aticonfig --initial
or:
sudo amdconfig --initial
If you are using multiple AMD graphics cards or AMD dual graphics (i.e.: notebook users), use:
sudo aticonfig --adapter=all --initial
or:
sudo amdconfig --adapter=all --initial
Reboot again.
See https://help.ubuntu.com/community/BinaryDriverHowto/ATI for details.
Panther
  • 104,528
