Trying to install the ubuntu-sdk on Ubuntu 12.04 64bit using instructions at http://developer.ubuntu.com/get-started/gomobile/ and I get the following errors:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: ubuntu-sdk : Depends: ubuntu-qtcreator-qt5libs but it is not going to be installed Depends: ubuntu-qtcreator-plugins but it is not going to be installed E: Unable to correct problems, you have held broken packages.
it appears that android-tools-adb is missing. I am able to get this installed but when trying to install ubuntu-sdk I am told that there is a an error (conflict with qt4 and qt5) and that qtchooser will not install.
E: /var/cache/apt/archives/qtchooser_0.0.1~git20121229.g8f08405-0ubuntu1~precise1~test5_amd64.deb: trying to overwrite '/usr/bin/qdbusxml2cpp', which is also in package libqt4-dev
I hear some people saying that the sdk can only be installed on Ubuntu 12.10....is this still the case? I really want to write apps.
Thanks in advance...
karel
  • 122,292
  • 133
  • 301
  • 332
Cantormath
  • 109
You can install it on 12.04 as well. The workaround is to manually install the package:
sudo dpkg --force all -i /var/cache/apt/archives/qtchooser_0.0.1~git20121229.g8f08405-0ubuntu1~precise1~test5_amd64.deb
sudo apt-get -f install
rmagyar
I had a dpkg error on 12.04 that stopped on qtchooser also.
Installing the package from the archive didn't work as shown but it worked after I copied the file from the /var/cache/apt/archives to my home directory and did the sudo dpkg --force all -i from there.
Also the name of my qtchooser package was slightly different but it was easy to get because it was displayed in the original error message.
vayu
