I want to add some text to the GNOME panel in GNOME Classic.
I got a suggestion from this blog but it dates back to 2008 and doesn't seem applicable now.
In Ubuntu 12.10 and GNOME classic, the option of /apps/panel/applets/clock_screen0/prefs/custom_format in gconf-editor is missing.
So is there any way I can add custom text to the clock in GNOME classic?
Also is there any other applet/extension available which allows us to add a text to the GNOME panel?
user.dz
  • 49,176
Shambo
  • 205
Simple Gnome extension may be worth to try. (I'm not sure about naming, in Ubuntu 14.04: Gnome classic uses same Gnome shell extensions, Where old classic renamed to Gnome Fallback)
Gnome Classic & Mate
  1. Download panel-applet-generator
  2. Generate a new applet:
    python panel-applet-generator.py -n mylabel -d "my custom label"
  3. Modify mylabelApplet.py
    try:
        from gi.repository import Gtk
    except: # Can't use ImportError, as gi.repository isn't quite that nice...
        import gtk as Gtk
    def applet_factory(applet, iid, data = None):
        button = Gtk.Button("It works!")
        label = Gtk.Label("It works!")
        applet.add(label)
        applet.show_all()
        return True
    I added label = Gtk.Label("It works!") and modified applet.add(label) (It was applet.add(button))
  4. Compress mylabel folder as tar.gz then rename it to mylabel_1.0.orig.tar.gz
  5. Build Debian package
    cd mylabel/
    debuild -us -uc
  6. Install package
    sudo dpkg -i ../*.deb
  7. Alt+Right Click or Super+Alt+Right Click on panel, then add to panel
  8. Look for mylabel applet, then add
References:
Note:
  • If for any reason unable to install, It is possible to do it manually:
    sudo cp org.gnome.applets.mylabel.panel-applet /usr/share/gnome-panel/4.0/applets/
    sudo cp org.gnome.panel.applet.mylabel.service /usr/share/dbus-1/services/
    sudo cp *.py /usr/lib/gnome-applets/
    32bit system:
    sudo cp mylabel.server /usr/lib/bonobo/servers/
    64bit system:
    sudo cp mylabel.server /usr/lib/x86_64-linux-gnu/bonobo/servers/
Gnome Shell
I have tested it with Gnome 3.10:
  1. Install Gnome tweak tool
    sudo apt-get install gnome-tweak-tool
  2. Create new extension:
    gnome-shell-extension-tool --create-extension
  3. Enter requested info: name My Label, description Extension shows my custom text, uuid mylabel@yourname or leave as default mylabel@hostname
    Extension created in /home/username/.local/share/gnome-shell/extensions/mylabel@hostname
  4. extension.js is auto opened. Replace Icon with your custom label. As below:
    function init() {
        button = new St.Bin({ style_class: 'panel-button',
                              reactive: true,
                              can_focus: true,
                              x_fill: true,
                              y_fill: false,
                              track_hover: true });
        let icon = new St.Icon({ icon_name: 'system-run-symbolic',
                                 style_class: 'system-status-icon' });
        let label = new St.Label({ text: "Hello, world!" });
        button.set_child(label);
        button.connect('button-press-event', _showHello);
    I added let label = new St.Label({ text: "Hello, world!" }); and modified 'button.set_child(label); (It was button.set_child(icon);)
  5. Save, Restart Gnome-Shell using Alt+F2, enter r then Enter
  6. Launch Gnome Tweak Tool → Extensions → Enable My Label extension.
  7. Restart Gnome-Shell again.
References:
user.dz
  • 49,176
on 20.04, there is this working extension that can use dbus to set the text:
https://extensions.gnome.org/extension/2826/generic-monitor/?c=78316
and here the readme:
http://indefero.soutade.fr/p/genericmonitor/source/tree/master/README.md
and this is what I use (a 1min loop), as I can't find another way to cfg datetime the way I want:
while true;do
  strDate="`date +"%A, %Hh%Mm - %d %B (%m/%Y)"`";
  gdbus call --session --dest org.gnome.Shell --object-path /com/soutade/GenericMonitor --method com.soutade.GenericMonitor.notify \
    '{"group":"new","items":[{"name":"first","text":"'"$strDate"'","style":"color:white"}]}'
  sleep 60
done
VeganEye
  • 161
If anyone's (still) looking for it, here's a much easier solution. A gnome extension called One Thing (named after a similar app for Mac)
https://extensions.gnome.org/extension/5072/one-thing/
Aneeez
  • 661
