Just installed Ubuntu 12.04 a couple of weeks ago on my HP laptop (completely replaced Windows). Everything seemed fine until a few days ago when I was unable to connect to the internet with my wireless network at home. I also tried three other wireless networks and also tried to connect by ethernet cable. These are all networks that I have been able to connect to in the past with no problems. In each case it says that I am connected to the network, but when I open Firefox I get the message "Firefox can't find server at start.ubuntu.com". I also tried Google Chrome and that didn't work either.
However, there is one network that I can connect to; the secure network at my school. The first time I noticed this problem was after I installed some updates at school and then went home and couldn't connect. I'm not sure if it had anything to do with these updates or if that's just a coincidence. When I came back to school it was fine and then it stopped working again went I went home.
Here's what I get for the following commands that phipsalabim suggested:
~$ lspci -v | grep -iA 7 network
02:00.0 Network controller: Intel Corporation Centrino Wireless-N 1000
Subsystem: Intel Corporation Centrino Wireless-N 1000 BGN
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at d2500000 (64-bit, non-prefetchable) [size=8K]
Capabilities: <access denied>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
~$ iwconfig
 lo        no wireless extensions.
 wlan0     IEEE 802.11bgn  ESSID:"My School Secure"
           Mode:Managed  Frequency:2.437 GHz  Access Point: DC:7B:94:87:AE:E1
           Bit Rate=65 Mb/s   Tx-Power=14 dBm
           Retry  long limit:7   RTS thr:off   Fragment thr:off
           Power Management:off
           Link Quality=52/70  Signal level=-58 dBm
           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
           Tx excessive retries:3300  Invalid misc:570   Missed beacon:0
 eth0      no wireless extensions.
Note that I'm at my school where I do have access.
~$ rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
~$ lsmod
Module                  Size  Used by
snd_hda_codec_hdmi     32474  1
snd_hda_codec_idt      70795  1
bnep                   18281  2
rfcomm                 47604  0
bluetooth             180153  10 bnep,rfcomm
parport_pc             32866  0
ppdev                  17113  0
binfmt_misc            17540  1
snd_hda_intel          33773  5
snd_hda_codec         127706  3 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel
snd_hwdep              17764  1 snd_hda_codec
snd_pcm                97275  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
i915                  477611  3
drm_kms_helper         46978  1 i915
snd_seq_midi           13324  0
snd_rawmidi            30748  1 snd_seq_midi
snd_seq_midi_event     14899  1 snd_seq_midi
arc4                   12529  2
drm                   241971  4 i915,drm_kms_helper
snd_seq                61929  2 snd_seq_midi,snd_seq_midi_event
uvcvideo               72627  0
videodev               98259  1 uvcvideo
snd_timer              29990  2 snd_pcm,snd_seq
hp_wmi                 18092  0
joydev                 17693  0
sparse_keymap          13890  1 hp_wmi
snd_seq_device         14540  3 snd_seq_midi,snd_rawmidi,snd_seq
v4l2_compat_ioctl32    17128  1 videodev
hp_accel               25976  0
psmouse                97485  0
wmi                    19256  1 hp_wmi
lis3lv02d              19876  1 hp_accel
i2c_algo_bit           13423  1 i915
video                  19651  1 i915
iwlwifi               401140  0
mac_hid                13253  0
wacom                  53300  0
serio_raw              13211  0
input_polldev          13896  1 lis3lv02d
lp                     17799  0
mac80211              506862  1 iwlwifi
snd                    79041  19 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_ra    wmidi,snd_seq,snd_timer,snd_seq_device
cfg80211              205774  2 iwlwifi,mac80211
soundcore              15091  1 snd
snd_page_alloc         18529  2 snd_hda_intel,snd_pcm
parport                46562  3 parport_pc,ppdev,lp
hid_logitech_dj        18730  0
ums_realtek            18248  0
usbhid                 47238  1 hid_logitech_dj
hid                    99636  2 hid_logitech_dj,usbhid
r8169                  62154  0
usb_storage            49198  1 ums_realtek
And for the wired connection.
~$ lspci -v | grep -iA 10 ethernet
   01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
   Subsystem: Hewlett-Packard Company Device 3662
   Flags: bus master, fast devsel, latency 0, IRQ 43
   I/O ports at 2000 [size=256]
   Memory at d0410000 (64-bit, prefetchable) [size=4K]
   Memory at d0400000 (64-bit, prefetchable) [size=64K]
   Expansion ROM at d0420000 [disabled] [size=128K]
   Kernel driver in use: r8169
   Kernel modules: r8169
COM
  • 101
Ok, everything looks fine. I am pretty sure this is a N-speed issue.
When you get home. Open the terminal and run:
sudo ifconfig wlan0 down
this turns off your wifi. Then run
sudo rmmod -f iwlwifi
this removes the module
sudo modprobe iwlwifi 11n_disable=1
this reloads the module with an additional option
sudo ifconfig wlan0 up
this puts the wifi interface back up.
When you're done, connect to wifi and check if web pages are rendered
These changes only apply to the current session. If this fixes the issue you will have to make them permanent.
In the terminal run:
gksudo gedit /etc/modprobe.d/iwlwifi.conf
in the opened file (iwlwifi.conf) add this line
options iwlwifi 11n_disable=1
If that doesn't fix the issue, report back. I will bow my head in shame, and I'm sure someone more knowledgeable than me will figure out your problem.
good luck
Ethernet issue
12.04 is not compatible with your ethernet card. To fix this.
Download the driver from this page (scroll down to the linux/unix section and download the linux driver from the closest mirror) to your ~/Download folder
then in the term run:
gksudo gedit  /etc/modprobe.d/blacklist.conf
at the end of the file append:
blacklist r8169
save and close file, finally run:
sudo update-initramfs -u && cd ~/Downloads && tar xvf r8101-1.023.00.tar.bz2 && cd r8101-1.023.00 && sudo sh autorun.sh
reboot
phipsalabim
  • 2,680
