10
Each time I switch to manual configuration, of wired connection in Ubuntu 12.10, the save button gets grayed out. As soon as I start setting it in Manually, it gets grayed out.Please help !
One more thing, system continuously displays a message at the top-right corner of the screen, saying:
Wired Network- Not connected
BuZZ-dEE
  • 14,533
sourav gupta
  • 101
Found the solution: It's a GUI problem: When adding static IP you may end up with an 'invisible' blank line in the list of IP addresses which prevents saving settings - just click below your IP address and delete the blank entry.
Vytas
  • 69
The button is greyed-out if there a missing or wrong information filled in the fields. Make sure you put it in like this:
  • IP Address: 192.168.1.20
  • Netmask: 24
  • Gateway: 192.168.1.1
  • DNS: 192.168.1.1 (not required for having a save-button)
Otherwhise please give us a Screenshot.
BuZZ-dEE
  • 14,533
prophecy201
  • 2,760
  • 17
  • 22
I faced the same problem, the way around is to do it from command line. Go to the file /etc/network/interfaces and change it to
auto eth0
    iface eth0 inet static
    address xx.xx.xx.xx
    netmask xx.xx.xx.xx
    gateway xx.xx.xx.xx
    dns-nameservers xx.xx.xx.xx
    dns-search xx
where you have to fill the xx given by your ISP.
Then from commandline do
sudo ifup eth0
BuZZ-dEE
  • 14,533
In my experience this happens when information is missing. The so far mentioned answers are correct. I would also like to add additional scenario - wireless. In my case I had a 802.1x. I couldn't save the password I have entered in my setting post-creation of the profile itself. I forgot to add the certificate. After I did that it all worked fine and the Save button was enabled again. In this case I could have also chosen the option not to require a certificate but either way one of both had to be entered as information.
In short - always check if you have entered all the information that is required from you for the network profile you are creating.
rbaleksandar
  • 328
