19
I have a Lenovo IdeaPad Y580 that I'm planning on dual booting with. I want to use Ubuntu 13.04, but on the daily builds download page there is only "PC (Intel x86) desktop image" listed for intel, and "64-bit PC (AMD64) desktop image" listed for AMD CPUs. Is there no 64bit for intel? should I just use the 32bit? Or should I just download 12.10 instead?
Eric Carvalho
  • 55,453
EvilBlob
  • 688
Yes, there is a 64-bit daily build of Ubuntu Raring Ringtail (soon to be Ubuntu 13.04) for Intel cpus. In fact, you mentioned it: it's the one that is called "64-bit PC (AMD64) desktop image". Yep, that's a confusing name and I'm sure it's called problems in the past, but that's the right one. (There's some sort of history behind the name, but it is correct.) It's the one I'm using with my 64-bit Intel cpu and it works perfectly. Download and use it with confidence with your Intel cpu.
Kelley
  • 34,252
"64-bit PC (AMD64) desktop image" is also for Intel's platform.
AMD64 is just the name of the instructions, and AMD and Intel processors are both able to understand them.
Eliah Kagan
  • 119,640
While the 64-bit PC image says AMD64 it does not mean it is only for AMD CPUs. This is the architecture description because the AMD64 instruction set became the prevailing instruction set for 64-bit consumer CPUs based on the x86 platform.
dobey
  • 41,650
