185
These two nice SE posts (1, 2) comment on restarting one's ubuntu machine but they leave me with a few questions:
  1. How do you actually do the restart (I'm a beginner and using 12.04.1 LTS)?
  2. Should I always restart the system when prompted to?
  3. Does restarting the system affect access to it via SSH or there any other caveats one needs to think about before doing this?
tim peterson
  • 2,345
6 Answers6
185
Should I restart my computer when prompted?
Yes, you should. A restart is required when an update to the Linux kernel has been installed. These updates are usually security updates, and then only come into effect after a reboot. When it comes to updates to applications like LibreOffice Writer, you only need to restart the application to apply the update, there's no need to reboot. Updates to a Snap application won't be installed while the application is still running.
If you wish to avoid having to restart your computer after an update to the kernel, you can use Ubuntu LivePatch Service. This is included with Ubuntu Pro, which is free of charge for personal use.
How to restart:
To restart the computer in Ubuntu 23.04, click the system menu in the top right corner of the screen, and then click the power icon. In the sub-menu that appears, click "Restart...".
To restart from the command-line, run this command:
$ sudo reboot
The downsides of restarting:
On the whole, restarting is a safe operation. Of course, when you restart the computer, you lose all the information in RAM, so make sure you save all open documents and files before shutting down your computer. While you are restarting, your computer will be offline for a few minutes. If you're running a server, it will be down for a few minutes. If you have an open SSH session, it will be terminated. You may need to manually start services that weren't configured to start automatically. If you're using full-disk encryption, you will need to authenticate yourself to decrypt the disk.
Flimm
  • 44,031
72
You may view the list of packages that require a restart with:
more /var/run/reboot-required.pkgs
Based on the list, you can decide whether it is worth restarting.
Example of output:
user@server:~$ more /var/run/reboot-required.pkgs
libssl1.0.0
linux-image-4.4.0-62-generic
linux-base
linux-base
linux-image-4.4.0-63-generic
linux-base
linux-base
linux-image-4.4.0-64-generic
linux-base
linux-base
network-manager
linux-image-4.4.0-66-generic
linux-base
linux-base
linux-base
linux-base
linux-base
linux-base
linux-base
network-manager
(The answer was tested on Ubuntu 14.04 LTS x64 and Ubuntu 16.04 LTS x64)
11
  1. How to restart:
    $ sudo reboot
    Or
    $ sudo init 6
  2. Yes as its most probably a security updates.
  3. Nothing will affect ssh connectivity after restart.
snoop
  • 4,110
  • 41
  • 58
Another caveat I haven't seen anyone else mention:
If the box you are SSH'ing into is connected via wifi then when you reboot you may not have access to the wifi network until a user physically logs in in at the remote machine which means SSH will fail since the box won't be connected to the network.
To avoid this, on the remote machine you have to configure the wifi in advance to be available to all users. Click the network icon in the system tray and choose "Edit Connections..", select your wifi network and click edit button, then make sure "Connect automatically" and "Available to all users" check boxes are checked.
You can also apparently solve this by messing with /etc/network/interfaces and wpa_supplicant but I found that road much more complicated than simply checking the box.
Side note: For me, before making the above change, connecting from WSL on windows to an ubuntu box gave "Resource temporarily unavailable". Googling this will take you down a rabbit hole of possible WSL bugs, but for me the problem was simply that the wifi wasn't connected until someone logged in. Applying the above fix solved the issue.
User
  • 1,493
  1. Another option is using sudo shutdown -r now
  2. If prompted, you should do so; as system have things need to be applied (most common if you choose to download and install updates automatically, or you have changed something yourself that requires a reboot to apply changes to your system).
  3. SSH will definitely be affected on a reboot and it will be terminated. I may suggest Putty as it will give an option on its context menu to reconnect the session.
snoop
  • 4,110
  • 41
  • 58
Ahmadgeo
  • 1,421
Always try to Restarting the pc after ubuntu updates, install drivers and some application that wants to restart the OS(ubuntu).
when new updates are installed or driver is installed these wants to restart the OS for working performance and properly use.
Normal application or package don't need to restart the OS after installed.
