42
I'm answering a question with a suggestion to use rename, and I realize I don't know what package it comes from (as part of the answer, I imagine saying something like "if you don't have rename, it's installed as part of [package]").
man rename tells me to SEE ALSO: mv(1), perl(1) - so my first thought is that it was installed with perl.
A related answer, how to tell what was installed as part of a package, helps me figure out that the perl package includes prename but not rename - and it turns out that my /usr/bin/rename points to /etc/alternatives/rename which points to /usr/bin/prename
So this is still kind of confusing. Did /etc/alternatives/rename point somewhere else before I installed perl? Is there a general way to tell which package something comes from?
Ternary
  • 4,187
install apt-file
$ sudo apt-get install apt-file
update apt-file
$ sudo apt-file update
search the package a file belongs to
$ apt-file search filename
find path of executable
$ whereis rename
rename: /usr/bin/rename.ul /usr/bin/rename /usr/bin/X11/rename.ul /usr/bin/X11/rename     /usr/share/man/man1/rename.1.gz /usr/share/man/man2/rename.2.gz
search package
$ apt-file search /usr/bin/rename
ladr4-apps: /usr/bin/renamer
util-linux: /usr/bin/rename.ul
the package name is: util-linux
phipsalabim
  • 2,680
25
Turns out dpkg-query is good to get information about installed packages, and with the -S [pattern] option will search for packages with files corresponding to [pattern].
dpkg-query -S [filename-search-pattern]
Ternary
  • 4,187
As of 2018
apt search filename
works for recent Ubuntu and most Debian based distros.
Update May 2018: Apparently no longer working with Ubuntu 18.04.
You can try apt-file (it's not part of default installation).
0) Update apt-file database
1) Find binary
$ which rename
/usr/bin/rename
2) Find the package
And voila -- rename is part of util-linux
