10
Possible Duplicate:
Where is the X.org config file? How do I configure X there?
I'm trying to get my video card properly setup to handle 3D acceleration. After searching a bit, I've come across a few howtos that tell me I need to edit my xorg.conf file. That file doesn't exist. X.org is installed by default, I'm sure, and I figured this video card would be widely supported.
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 09)
Any ideas on how I can get this to work properly and play Starcraft II? Or any game for that matter? No resolution problems or anything, just no 3D rendering.
BBetances
  • 245
You COULD create your own xorg.conf by typing in a tty (not running gdm) the following:
X -configure
That will create a file called xorg.conf.new
To test the file type X -config xorg.conf.new
If you can load X and see the mouse and a good resolution then you can press CTRL+ALT+BACKSPACE to quit.
Copy then xorg.conf.new to the new location
cp xorg.conf.new /etc/X11/xorg.conf
Run startx to test.
Also the file does not exist since X.org does not needed anymore for some video cards (as i understand) only some Video cards have xorg.conf because of specific configurations (Like Nvidia and Ati). The rest of the X.org configuration options are in /usr/share/X11 like synaptics.
Now to test out if you have Direct Rendering do this:
glxinfo | grep -i "Direct Rendering" If it says YES then you can run several games. If it says NO then you might need more configuration. Also run glxgears to see how many FPS you have. If the glx commands are not there run sudo apt-get install mesa-utils
I can not guarantee that it will make it work for starcraft 2 (Remember you also need to have wine installed)
Luis Alvarado
  • 216,643
