19
Recently VLC has been having issues displaying video in fullscreen mode. AFAIK, nothing has changed with the video card drivers and it's certainly the same version of VLC. (/me shakes a fist at the repository maintainers)
This has worked without issue in the past. In fact, I've had as many as 6 instances of VLC running, each playing a video. One was always fullscreen on my second monitor, while the others were tiled on my primary monitor. I was able to toggle any of the other 5 into fullscreen mode and the video displayed without issue.
Lately, I've been having trouble running 2 instances in fullscreen mode. (Sometimes, even a single instance will not display the video in fullscreen.) VLC will continue to play the video, but in fullscreen mode I see nothing but a black screen. Sometimes, the video will display if I maximize the VLC window. Other times, I have to settle for a smaller sized window.
I don't know if this is pertinent, but sometimes changing the min/max state of a Firefox window (Minefield, specifically) seemed to allow the troublesome instance to display the video in fullscreen mode. However, that did not prove to be a consistent workaround. Sometimes, it seemed that closing a Firefox window did the trick, though that isn't consistently successful either. (I futzed with Firefox, because with the crazy number of windows and tabs that I normally have open, it regularly hogs about 1 GB of RAM.)
Another bit of funkiness that comes to mind is the fact that my secondary monitor is considered the primary on boot-up. I use xrandr to designate the real 1st monitor as primary after boot-up, as suggested by someone in a question I asked on the Unix & Linux SE site.
Specs:
  • Ubuntu 10.10 w/ Gnome and Compiz
  • 8GB RAM
  • AMD Phenom II 965 Black Edition
  • Asus M4A79 Deluxe mobo
  • XFX ATI Radeon HD 5750 w/ 1GB RAM
VLC is configured to use the hardware overlay for video (as per the default setting)
Does anyone have an idea what may cause this issue or how I may go about troubleshooting it? Right now I have 2 instances of VLC playing, each in fullscreen mode on a separate monitor.
In Tools > Preferences > Video > Output change the Default to X11, save and restart vlc.
timendum
  • 181
Two things you should know about VLC:
1. If you have compiz activated you will have some issues with VLC showing the video from a movie.
2. If you have multiple displays it will have some issues with VLC choosing which display to show the video in.
So for what i have read, you have both of this. From my experiences with similar cases i recommend to disable compiz and afterwards test the displays. To disable compiz just ALT+F2 and type metacity --replace or you can just go to System -> Preferences -> Appearance and select the Visual Effects Tab then select none.
Second, to test the display problem.
First test if you can see the video on 1 display (without the other one connected).
Second test (with the video closed. Do not open it yet) with both monitors connected and in "clone mode". Run the video and see if it appears in both displays.
Third and last, remove the "clone mode". Put one to the right or left and open 2 instances of VLc. move one of the instances to the left/right display and the other one leave it on the base display.
this is the way i do when i have black screen issues with vlc. This is because of some issues with compiz and with having multiple displays since VLC does not know to which to show the display.
Test all this and let us know.
Luis Alvarado
  • 216,643
Given the number of good answers, if you are still having problems - I suggest filling a bug report with vlc and launchpad. (Search for similar bugs first.)
Syborgia Alphas
  • 302
Not knowing much about computers, you might try this:
http://forum.videolan.org/viewtopic.php?f=13&t=78308
from VLC
