-2
When I open a PDF file, it doesn't display text. Graphics show up.
How do I get the PDF viewer to display text?
Jorge Castro
  • 73,717
dgb
I erased my machine and re-installed 12.10. Right before I added all the fonts I know and love, the PDF viewer works.
AFTER... I add the fonts, it stops working. I can only guess that one of the new fonts is overwriting a "core" font Ubuntu needs to make the PDF viewer work.
Anyone know how to restore that font?
I could go through the 900 I install one at a time to see which one is doing it, but that seems like it would take a while.
From: http://ubuntuforums.org/showpost.php?p=12516767&postcount=13
the phrase "core" font made me wonder if Ubuntu had such a thing... it does.
In /usr/share/fonts/truetype
I add my own folder called "myfonts" with 900 .TTF files. When I remove that, the PDF viewer works.... sooo.... I found a folder called "ubuntu-font-family" and copied the contents of that folder to "myfonts" folder overwriting my substitutions with the system originals.
That worked.
The PDF viewer is working normally now. Thank you all.
From http://ubuntuforums.org/showpost.php?p=12516785&postcount=14
In other words, OP has the solution here: [SOLVED] PDF files show no text in 12.10
How are you able to create a folder in the usr/share/fonts/truetype when it's disabled?
and is there a way to install multiple fonts instead of opening and installing them one at a time?
I only have one pdf file that doesn't show the text while it opens other pdf files with no problem.
-2
There are two choices you can make, one is to install Adobe Reader, the other is if you're using Chrome / Chromium, to make that the default .pdf reader.
scouser73
  • 4,344
