This cropped up somewhere during the process of installing an nvidia driver (310.32) for my graphic card. Whenever I clicked on the Ubuntu Software Center icon on the launcher, it seemed to work (animation on icon to show that it was starting), and then nothing. So I did the first stupid thing, I tried to remove and reinstall the Software Center; apparently, the remove didn't work properly, so I tried again. Here's the terminal session:
parth@Gladoss:~$ sudo apt-get remove software-center
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  software-center
0 upgraded, 0 newly installed, 1 to remove and 304 not upgraded.
1 not fully installed or removed.
After this operation, 4,485 kB disk space will be freed.
Do you want to continue [Y/n]? Y
(Reading database ... 176079 files and directories currently installed.)
Removing software-center ...
dpkg: error processing software-center (--remove):
 unable to securely remove '/usr/share/app-install/menu.d/featured.menu': Not a directory
No apport report written because MaxReports is reached already
 software-center
parth@Gladoss:~$
Let me know how I can properly remove and reinstall the program. Thanks.
EDIT: command sudo apt-get update comes to a stop with error message (terminal)
W: GPG error: ppa.launchpad.net quantal Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4F191A5A8844C542
EDIT: Tried the commands: (i)sudo rm /usr/share/app-install/menu.d/featured.menu result : directory does not exist. (ii)sudo rm -rf /usr/share/app-install/menu.d/featured.menu result : nothing. Terminal just gets ready to accept new line. Further, I tried "sudo apt-get install software-center". Same error message as original post.
EDIT: sudo apt-get --reinstall install software-center returns
(Reading database ... 176080 files and directories currently installed.) Preparing to replace software-center 5.4.1.2 (using .../software-center_5.4.1.4_all.deb) ... Unpacking replacement software-center ... dpkg: error processing /var/cache/apt/archives/software-center_5.4.1.4_all.deb (--unpack): trying to overwrite '/usr/share/app-install/desktop', which is also in package app-install-data-partner 12.12.10 Processing triggers for desktop-file-utils ... Processing triggers for bamfdaemon ... Rebuilding /usr/share/applications/bamf.index... Processing triggers for gnome-menus ... Processing triggers for hicolor-icon-theme ... Errors were encountered while processing: /var/cache/apt/archives/software-center_5.4.1.4_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
EDIT : I figured something was wrong with the dpkg, I googled that. Some commands I tried afterwards.
parth@Gladoss:~$ sudo dpkg --audit The following packages are only half installed, due to problems during installation. The installation can probably be completed by retrying it; the packages can be removed using dselect or dpkg --remove: software-center Utility for browsing, installing, and removing software
parth@Gladoss:~$ sudo dpkg --remove software-center (Reading database ... 176079 files and directories currently installed.) Removing software-center ... dpkg: error processing software-center (--remove): unable to securely remove '/usr/share/app-install/menu.d/featured.menu': Not a directory Errors were encountered while processing: software-center
[In succession]
EDIT : sudo dpkg -L software-center brings up a whole lot of files; including /usr/share/app-install/menu.d/featured.menu If it's being shown here, how is it that a recursive force remove ignores it? Are their any other commands (not related to rm) which might work?
Remove manually
Then try and reinstall Software Center
LnxSlck
  • 12,456
Taken from another thread - (Can I uninstall and reinstall Ubuntu Software Center?)
You've done step one of the top answer, now try the three other steps:
  1. sudo apt-get autoremove software-center
  2. sudo apt-get update
  3. sudo apt-get install software-center
The alternative is in Eliah Kagans answer
  1. sudo apt-get update
  2. sudo apt-get --purge --reinstall install software-center
Hopefully the previous thread can help more with this.
Timlah
  • 637
