After installing ubuntu using wubi and selecting UEFI and csm UEFI as disabled in samsung series 5 with window 8, wubi said files is missing.
Do i need to install with wubi again?
i read the answer, it said to use livecd, but i only hope not actual install in partition, only expect wubi in windows 8, after read, it is quite terrible to install partition with livecd , it said choose anything you want during installation, but i already installed in window 8 already. Why install again using livecd. finally it said it may not boot window 8 any more. is it possible to keep using window 8 boot manager to boot ubuntu?
You can't just switch from UEFI to CSM and expect it to boot. That will just stop Windows booting. Wubi doesn't work on UEFI period.
Wubi doesn't work on UEFI computers due to the partition table the disk uses. The only way to get it to work would be to completely reformat, reinstall Windows and then install Wubi.
Even then, replacing a GPT disk with MBR partition table doesn't clean up all GPT data and Ubuntu will fail to install due to exceptions thrown from parted. You'd have to download a program called fixparts to completely erase the GPT data.
This is obviously an excessive amount of effort to go to in order to install Wubi which is generally intended to try out Ubuntu safely.
Since Wubi does not support any new computers shipping with Windows 8, or any computer booting via UEFI you have to choose an alternative method of which there are many:
  1. normal dual boot
  2. replace Windows
  3. install (non Wubi) to an external drive
  4. install in a virtual machine
  5. run from a live USB with persistence
  6. run from a live DVD
bcbc
  • 6,036
