I'm currently using Ubuntu 12.10 64bit alongside with Windows 7 Professional 64bit on a custom hardware desktop PC, and I've noticed that I don't have the correct drivers for Ubuntu, since I'm experiencing some graphical and sound glitches.
So... how can I install the correct drivers for my pc without affecting my Windows 7 drivers, that's pretty much it.
Thanks
Ps: My hardware is: (sorry for not having this here in the first place)
  • Grapics Card: Nvidia GeForce GTS 450
  • Motherboard: Asus P7P55 LX
  • CPU: Intel Core i5-650
Your ubuntu drivers will not affect your windows drivers in any way whatsoever.
The additional drivers tool should do the trick for most things, though with 12.10 it may need a little additional help (read on!).
Unfortunately there's some minor issues with the way ubuntu 12.10 is set up (basically, the packages needed to build a dkms module arn't pulled in automatically, so its just a tiniest bit more difficult than it has to be, and the additional drivers tool dosen't always tell you correctly if the drivers are activated.While these instructions are for nvidia, this will affect most things with non free drivers which often use use dkms.
You would probably want to install the experimental 310 drivers (which rock) if you run nvidia and test if the drivers work with something like unigine heaven or some other benchmark EVEN IF the additional drivers tool claims the drivers are inactive.
