When I use apt to get a package, I have been receiving the same error message. Here is an example trying to install wicd (which is already installed):
    Reading package lists...
Building dependency tree...
Reading state information...
wicd is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
3 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Setting up tex-common (2.06) ...
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend requires a screen at least 13 lines tall and 31 columns wide.)
debconf: falling back to frontend: Readline
Running mktexlsr. This may take some time... done.
No packages found matching texlive-base.
dpkg: error processing tex-common (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of texlive-binaries:
 texlive-binaries depends on tex-common (>= 2.00); however:
  Package tex-common is not configured yet.
dpkg: error processing texlive-binaries (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of dvipng:
 dvipng depends on texlive-base-bin; however:
  Package texlive-base-bin is not installed.
  Package texlive-binaries which provides texlive-base-bin is not configured yet.
dpkg: error processing dvipng (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
 tex-common
 texlive-binaries
 dvipng
I'm not sure if this is a problem with apt or with dpkg, but it certainly doesn't look good!
This is usually fixed with two commands:
sudo apt-get update
To update your database to the latest packages.
sudo apt-get -f upgrade
To upgrade and fix those packages.
Javier Rivera
  • 35,434
It looks like you are missing texlive-base Install texlive-base.
You can install it in the Software Center from that link, or in the Terminal (Ctrl+Alt+T) with:
sudo apt-get update
sudo apt-get install texlive-base
BMitch
  • 101
@Tshepang, Firefeater: The command was "sudo apt-get install X" where X is anything I've tried to install lately. I don't actually know whether or not I'm using the 3 packages it complains about. I certainly don't use them directly, but maybe some other thing I do use wants them.
@Javier Rivera: I ran the two commands you suggested. Many things happened, things were downloaded, and at the end, I got (again)
 tex-common
 texlive-binaries
 dvipng
Try sudo apt-get clean and sudo apt-get autoremove to see if this clears the error.
If you haven't tried to purge the packages, you can try that as well:
sudo apt-get purge texlive-base-bin
sudo apt-get purge texlive-binaries
sudo apt-get purge tex-common
Here's a launchpad bug page which I believe has relevant information.
There is also a thread on ubuntuforums where someone had a very similar problem.
belacqua
  • 23,540
