14
I was trying to make Sublime Text 2 start from the Terminal. I found a great resource but I cannot find where it is installed. I used the WebUpd8 PPA, anyone know where the PPA installs sublime.
Braiam
  • 69,112
mojo706
  • 601
I don't know the answer to this exact question, but to know wich files did a package install you can use this command:
dpkg -L <package name>
The best thing is that you can use tab completion with it so:
dpkg -L subli<tab>
is likely to give you the answer.
You can also use Synaptic to find this list through a GUI.
Javier Rivera
  • 35,434
The command for starting it is most likely
sublime-text-2
though try
sublime-text
and
subl
These are the programs, or links that get installed to /usr/bin/ (if my limited understanding of deb packages is anything to go by, I don't actually use the software).
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Queeg
  • 51
