I tried to install steam but is impossible to run it
I get this when I try to run it
steam
Running Steam on ubuntu 12.10 64-bit
STEAM_RUNTIME is enabled automatically
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
Installing breakpad exception handler for appid(steam)/version(0_client)
Installing breakpad exception handler for appid(steam)/version(1.0_client)
SteamUpdater: Error: Download failed: http error 0SteamUpdater: Error: Steam needs to be online to update.  Please confirm your network connection and try again.
Installing bootstrap /home/elin3t/.local/share/Steam/bootstrap.tar.xz
STEAM_RUNTIME has been set by the user to: /home/elin3t/.local/share/Steam/ubuntu12_32/steam-runtime
and this is my hardware VGA
lspci | grep VGA
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RV710 [Radeon HD 4350]
And this my distro version
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.10
Release:    12.10
Codename:   quantal
thanks if some can help me!!
I tried the forum solution but I didnt found the registry.vdf file to change the lines
Jorge Castro
  • 73,717
elin3t
  • 331
I found the solution with this
cd .steam/
rm steam.pid
cd
rm .steampid
sudo apt-get install xfonts-100dpi xfonts-75dpi
Then run steam again!
if it doesn't work at first, restart
Zanna
  • 72,312
elin3t
  • 331
I solve the problem in my laptop with the command:
steam --reset
my laptop is an acer aspire 5742G with an intel core i5-480m and an Nvidia Geforce GT 540m, I use bumblebee to avoid optimus problems.
lucas
