After the latest update, Rhythmbox (which was my main mp3 player on my Ubuntu Latest distro) stopped functioning: it dies just after startup. So, I turned to Clementine which I like a lot. However in Rhythmbox I had my playlists and ratings. Song ratings are very important to me because many of my auto-playlists are depending on them.
Is there anyway I can get my playlists and ratings from Rhythmbox and add them to Clementine?
Thanks.
xpanta
  • 1,521
To export a playlist select Music from the top menu and then Playlist, under which you have "save to file"
To export your ratings, create a smart playlist for each rating and then export those playlists too.
Sven
  • 77
Summary: fail, but probably for another reason
Hello,
Contrary to xpanta, my rhythmbox still works. So I used it to export playlists.
Then I launched Clementine to use that playlists to import ratings.
https://groups.google.com/forum/#!topic/clementine-player/yGCZAsZe704 explains how to show "rating" and "score" column.
But both columns appear always empty. Double-clicking on a cell in the "Score" column (and only that one) allows to edit one value, but after pressing entry cell becomes blank again. Also, any batch rating/score function.
Is there something wrong with my clementine installation ? It's plain default install from Ubuntu 13.10.
Perhaps it's because the content of my Music folder is only symbolic links to actual locations, as other users do, see :
Those operations worked to import into gmusicbrowser, see details in Transferring music ratings from rhythmbox to gmusicbrowser
I now use gmusicbrowser.
