I just got the last version 12.10-64bits, to install in my new HP 2000, and everything went fine, including the EFI installation in the original Windows 8 platform (I've followed this tutorial https://help.ubuntu.com/community/UEFI).
The only problem is that WiFi don't work. Anyone has passed by the same problem? If you need any information about the hardware, just tell me how I get it and I'll get it.
Here goes the outputs:
lspci:
07:00.0 Network controller: Ralink corp. Device 3290
07:00.1 Bluetooth: Ralink corp. Device 3298
08:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
rfkill list all:
0: hp-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
dmesg | grep -i firmware
[ 0.305939] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored [ 0.566226] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness [ 0.566570] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness [ 2.099004] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
sudo lshw -class network:
*-network UNCLAIMED
description: Network controller
product: Ralink corp.
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:07:00.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:f0210000-f021ffff
ifconfig:
eth0 Link encap:Ethernet HWaddr 84:34:97:93:47:a4
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1072 errors:0 dropped:0 overruns:0 frame:0
TX packets:1072 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:87792 (87.7 KB) TX bytes:87792 (87.7 KB)
iwconfig:
lo no wireless extensions
