Actually your problem seems to be that you haven't configured a network package repository and instead have still the line from installation time in there, referring to your installation media. The easiest thing would be to edit your /etc/apt/sources.list or grep -R 'deb cdrom' /etc/apt/ to see which of the files still refers to your installation media. Usually that would be /etc/apt/sources.list. Comment out the lines starting with deb cdrom: by prepending a # and then save.
After that make sure to also add some repositories. The normal method is to have contents such as these:
deb http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal main restricted
deb-src http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal-updates main restricted
deb-src http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal universe
deb-src http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal universe
deb http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal-updates universe
deb-src http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal multiverse
deb-src http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal multiverse
deb http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal-updates multiverse
deb-src http:/<country-code>.archive.ubuntu.com/ubuntu/ quantal-updates multiverse
deb http://security.ubuntu.com/ubuntu quantal-security main restricted
deb-src http://security.ubuntu.com/ubuntu quantal-security main restricted
deb http://security.ubuntu.com/ubuntu quantal-security universe
deb-src http://security.ubuntu.com/ubuntu quantal-security universe
deb http://security.ubuntu.com/ubuntu quantal-security multiverse
deb-src http://security.ubuntu.com/ubuntu quantal-security multiverse
where <country-code> would be a two-letter country code as used in ccTLDs, such as us for USA, de for Germany etc. Basically you "local" package repository mirror for added speed. Those lines should already exist and you probably don't need to add or adjust them at all. Simply commenting out the lines starting with deb cdrom should be enough.
After editing make sure to run:
sudo apt-get update
and watch out for further errors such as the ones from your question. Correct them until you see no errors and then install the packages you need or want.
Also make sure to consult man sources.list and this documentation. And here's an online tool to generate the entries for sources.list.
There is also a graphical method to this, but I have no experience in this, as I prefer to edit sources.list. Also the graphical method differs depending on the Ubuntu flavor you're using, such as vanilla Ubuntu, Kubuntu ... etc.
