Ubuntu 12.10 fresh install here.
So I just installed php with sudo apt-get install php5 + a few other packages like php5-curl. I executed php -v and noticed something pretty bizarre:
PHP 5.4.6-1ubuntu1.1 (cli) (built: Nov 15 2012 01:18:34)
Copyright (c) 1997-2012 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2012 Zend Technologies
    with Xdebug v2.2.1, Copyright (c) 2002-2012, by Derick Rethans
Notice the Xdebug extension installed? I did not install it through apt (php5-xdebug package), neither through pecl and neither from source!
Question. On Ubuntu, does PHP already comes with xdebug now?
marcio
  • 454
Marcio,
you might have accidentaly installed php5-xdebug as a dependency of some other package.
The default clean php5-cli installation just gives:
# php5 -v
PHP 5.4.6-1ubuntu1.2 (cli) (built: Mar 11 2013 14:57:54)
You can check installed binary modules in /usr/lib/php5/20100525 directory and then you can use dpkg -S to query the coresponding debian package (I have installed php5-xdebug manually meanwhile):
# dpkg -S /usr/lib/php5/20100525/xdebug.so
php5-xdebug: /usr/lib/php5/20100525/xdebug.so
If this doesn't show up anything then it means that somebody (or some automatic script) has installed the xdebug without you knowing.
oerdnj
  • 7,940
