I've been trying to figure out how to get my wireless driver to work since I installed Linux a month ago because Windows was crapping out on me. I'm new to Linux, so I'm unfamiliar with how to get certain things to work. Any suggestions?
01:00.0 Network controller [0280]: Intel Corporation Centrino Wireless-N 1030 [8086:008a] (rev 34)
    Subsystem: Intel Corporation Centrino Wireless-N 1030 BGN [8086:5325]
    Kernel driver in use: iwlwifi
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 05)
    Subsystem: Dell Device [1028:04d8]
    Kernel driver in use: r8169
*-network DISABLED
       description: Wireless interface
       product: Centrino Wireless-N 1030
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: wlan0
       version: 34
       serial: 4c:eb:42:77:d6:f2
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=3.5.0-23-generic firmware=18.168.6.1 latency=0 link=no multicast=yes wireless=IEEE 802.11bgn
       resources: irq:51 memory:d0600000-d0601fff
  *-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: eth0
       version: 05
       serial: 84:8f:69:d2:db:a4
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.1.73 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:49 ioport:2000(size=256) memory:d0404000-d0404fff memory:d0400000-d0403fff
Lucio
  • 19,191
  • 32
  • 112
  • 191
This had worked for me, but haven't figured out yet how to make it permanent.
Open terminal with Ctrl+Alt+T and type the following commands:
sudo rmmod -f iwlwifi
It may ask you to input your password after you press enter
sudo modprobe iwlwifi 11n_disable=1
The above will disable the N mode on your wireless card and it should start working.
Lucio
  • 19,191
  • 32
  • 112
  • 191
I realize this is an old question, but I just ran into this issue and it took some time to find an answer that worked. For me, I needed to go into the BIOS under "Advanced" settings and toggle "Function Key Behavior" to be "Function Key" instead of "Multimedia Key".
Then, when I was back in Linux I could use Fn-F2 to toggle on the wireless network interface. (This is the hardware switch.) At that point everything worked automatically.
