I'm totally new on Ubuntu. Just decided to kick out the horrible windows 8: so I downloaded the last version of Ubuntu available on the web site , tried out the live cd and found it quite interesting.
After starting to install I arrived to the part where I could choose and manage the partitions where I wanted to install Ubuntu. Being new to it decided not to touch where I wasn't sure as I didn't want to loose my data partition where I have accumulated my pictures for almost 6 years.
So I decided to go back and let the installation do it by itself. There was a warning saying I would lose all my data but I supposed it would be just on the windows partition. After the install finished I started to wonder around my new OS and realized that I couldn't find my data partition. I guess this is not a new question at all, but I'm just a bit scared as I don't want to loose all the data I had.
I've been reading and trying some solutions like mounting the partitions, but it seems that the only partitions I find is one called boot and another called swap along with sda2 which I tried to mount but got the message wrong nfts format.
So here is the big question: is there any chance to recover the partition or shall I forget about everything (my files) ?
Braiam
  • 69,112
getulio
Many of the answers above are much more reliable, but in case you've really messed it up, like I've done in the past, then you can try this as a last-resort option.
For this, you'll want to use TestDisk. Once you have installed and launched TestDisk on a LiveCD/USB:
  1. Select [Analyse]
  2. Select the disk that you want to recover from
  3. Select the partition table type. For most people it will be Intel/PC
  4. Following the analysis, TestDisk may find some partitions. If it finds your old data partition, simply have it written to the disk, and that should be that.
  5. If TestDisk doesn't find any/the right partition, try a deeper search. Once again, if this finds the partition, simply write it to the disk, and you're done.
  6. If, like in my case, TestDisk is unable to write the partition to the disk, you can try creating a new partition with the exact specifications (cylinders, heads, sectors, type) your old one had, and that should be able to recover it.
If data has been written to the disk where the old partition was, which is probably the only reason you would ever need to resort to step #6, then it is likely that some/many files will be corrupted; results may vary.
If you want to read the original tutorial where I found these steps, which includes descriptive pictures, click here.
ananaso
  • 4,080
  • 32
  • 52
It may be possible to undelete the data partition using a tool called testdisk (see here). If not, you can still probably recover the individual photos, documents, etc. by running photorec (which comes with testdisk).
Photorec will find files even after the partition has been formatted (as happened in your case), but you'll need to recover them to another drive - so you'll need to plug in an external drive. Depending on how important your data is to you, you might consider a professional data recovery service as well, but in my experience photorec works quite well (you do have to sift through everything manually though as the file names will not be recovered).
From the website:
PhotoRec is file data recovery software designed to recover lost files including video, documents and archives from hard disks, CD-ROMs, and lost pictures (thus the Photo Recovery name) from digital camera memory. PhotoRec ignores the file system and goes after the underlying data, so it will still work even if your media's file system has been severely damaged or reformatted.
To install testdisk and photorec from a live CD (make sure the Universe repository is enabled):
sudo apt-get update
sudo apt-get install testdisk
bcbc
  • 6,036
Yes. There is a good chance to recover your partitions. Nevertheless you must run the whole process from a CD/DVD/USB in order to recover your disk to the previous partition tables. You can't bring back a partition while part of/or the whole disk is mounted. So I suggest you to make a live-cd in order to run the process.
Parts of this answer comes from this previous answer.
The procedure I used is documented at the very bottom, placed here for your convenience:
IMPORTANT: Try not to use forensic recovery procedures and not to use MS based recovery tools in the first instance.
  1. First of all you calm down. Tranquil, if you erased or removed the partition's table, the data is still there. You need to find a way to bring it back, that's it.
  2. The most you can keep the drive off new data, the best for your data. If you write new data, the older data will be replaced by the new as this starts using the clusters.
  3. If possible, try not using MS based tools, which (in my case) just wrote a few clusters in the disk which made unusable some data. MS Recovery Tools (such as Easy Data Recovery and others) tries to read the partition table but it also writes some clusters which can't be fully read in order to recover the "usable part of the data". This may harm your data replacing the original allocation clusters with blank data which allows the software to gain access to the cluster itself.
  4. Follow the instructions shown on the video documented by amzertech, which was embedded in the previous post and that clearly explains exactly what I did in order to recover my data.
  5. If you follow these instructions, I am sure you are going to succeed. Even in the worst cases ([...]) you will succeed if you follow this easy instructions. Remember, the data will remain intact if you leave the disk intact. The most things you do to the disk, will be the most risk your data is reaching.
If you need further assistance don't hesitate to drop a comment.
Good luck!
