13
I am looking for a clipboard manager, but I don't want one that just keeps a list so I can select an item to bring it to the front of the clipboard, nah, that's too easy.
What I am looking for is a clipboard manager where I can assign say
Ctrl+Shift+1 to paste the first item in the clipboard,
Ctrl+Shift+2 to paste the second item in the clipboard
Ctrl+Shift+9 to paste the ninth item in the clipboard
Ctrl+Shift+0 to paste the tenth item in the clipboard
why?
As we web developer I am often pasting alternating lines of code (remember, not all browsers support CSS3!),
<tr class="odd">...</tr>
<tr class="even">...</tr>
So, the ability to just sit there doing
Ctrl+Shift+1 Enter
Ctrl+Shift+2 Enter
Would be a huge help,
I am using 12.10 with gnome-shell 3.6.2.
I have looked into gPaste and such, but none seem to have this feature.
Hailwood
  • 5,017
5 Answers5
I'm not aware of a clipboard manager that itself provides the feature you want, but there are two ways in which I imagine that Klipper could be incorporated in a solution.
  1. Klipper offers "Next History Item" and "Previous History Item" shortcuts that change the order of the clipboard history. Therefore, pasting the nth entry can be done by running the "Next History Item" shortcut n times, then running Ctrl+V (or whatever your paste shortcut is), and then -- to put the history back into its original order -- running the "Previous History Item" shortcut n times. Using this, your problem reduces to setting a shortcut that simulates entering a series of shortcuts.
  2. The command qdbus org.kde.klipper /klipper getClipboardHistoryItem n where the n at the end is a number (e.g. 0, 1, 2...) will output the nth clipboard history item. Using this, your problem reduces to the problem of setting a keyboard shortcut that will paste the output of a command.
GPaste is a clipboard management system for GNOME. GPaste manages clipboard history and allows easy access to it using keyboard shortcuts, gnome-shell extension and command-line tools.
To install GPaste in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install gpaste
Qlipper is a lightweight clipboard history applet. It provides the following features:
  • saves clipboard history entries and restores them
  • lightweight
  • system tray docking app
  • few requirements
  • can be used in GNOME
To install Qlipper in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install qlipper
CopyQ is an advanced clipboard manager with editing and scripting features. CopyQ monitors the system clipboard and saves its content in customized tabs. Saved clipboard entries can be later copied and pasted directly into any application.
To install CopyQ in Ubuntu 18.04 and later open the terminal and type:
sudo apt install copyq
karel
  • 122,292
  • 133
  • 301
  • 332
When Keepboard is activated, the second item in the history is selected by default (because the top item is in the clipboard anyway and can be pasted directly without activating clipboard manager). Thus you can quickly paste the second item by using Keepboard activation hotkey and pressing Enter right away.
Dragan
  • 41
I've released a clipboard manager Gnome extension that supports paste on select, including numbered keyboard shortcuts to select the Nth item.
I added this as a custom global command to CopyQ (https://github.com/hluk/CopyQ) a while back. CopyQ should work for any window manager. I'm using it with i3.
To add the feature to your CopyQ, you would follow these steps:
  1. Install CopyQ
  2. Download the paste-nminus1th-item command located at https://github.com/hluk/copyq-commands/blob/master/Global/paste-nminus1th-item.ini
  3. (optional): edit the command to the keyboard commands of your choosing. It seems like you like Ctrl+Shift+1,2, etc. So then you would have the paste-nminus1th-item.ini command be:
[Command]
Command="
    copyq:
    var n = str(data(mimeShortcut)).slice(-1)
    select(n-1)
    paste()"
GlobalShortcut=ctrl+shift+1, ctrl+shift+2, ctrl+shift+3, ctrl+shift+4, ctrl+shift+5, ctrl+shift+6, ctrl+shift+7, ctrl+shift+8, ctrl+shift+9
Icon=\xf0cb
IsGlobalShortcut=true
Name=Paste Nth Item
(I just added +shift to all the global shortcut values compared to the default paste-nminus1th-item.ini file).
  1. Open copyq (copyq; copyq show for me)
  2. Press F6 or find "load Global Commands" in the menu
  3. Select the "Load commands" button
  4. Find wherever you downloaded the paste-nminus1th-item.ini file and load it in as a command.
Now those keyboard commands should paste the Nth item in history that you copied
