Killing processes
Generally speaking for killing a process, there's no safer way to kill a process than with a regular kill (SIGTERM). In case it's an interactive process it usually allows you to stop it even safer by sending a SIGINT signal, usually sent by pressing Ctrl + C. This signal is being trapped by the process itself can listen to it - and usually stop gracefully. (thanks Eliah)
DPKG database
Regarding the package management is a sort of special case. The DPKG database that the APT commands use under water can always detect whether an operation hasn't finished. Every package has an actual state which is marked in as well as a current state, e.g. unpacked, configured, etc. By killing the APT frontend, the database will be in a broken, but in known state. The lock files will only be released once it's all back in a clean state - you should get this fixed until it allows new operations.
The way to fix is just firing a process to get all packages in the configured state. Practically speaking, if you've interrupted an apt-get operation, you can just finish it later using
sudo dpkg --configure -a
It knows how to recover from the broken state to an all-configured state and in that sense just continue from where it was interrupted. The lock files are left there until you finished that, and that's for a reason - to prevent new operations with the DPKG database in an unclean state.
About SIGKILL (9)
Sending a SIGKILL (decimal representation 9) is very unsafe. This signal is cannot be caught by the process, but the whole process will be cleaned up by the operating system (kernel) whether the process likes it or not. The state of the files on the file system can be left in a corrupt state. Never send these signals unless it's not listening to other more graceful signals anymore.
