I am trying to install nagios but I would like to start the web interface on a port other than 80. I cant seem to find much info on how to do that. Any help is appreciated. Thanks
I just worked on this, and figured it out. It's not ideal for some, but for me it works perfect. I just changed the default port apache2 looks at by :
Changing /etc/apache2/sites-available/default First line ( Default ) :
<VirtualHost *:80>
Changed to :
<VirtualHost *:8085> # Change 8085 to whatever port you want
then linking default in sites-enabled ( not sure if this site is needed, but it works )
cd /etc/apache2/sites-enabled/
ln -s ../sites-available/default default
then cycle apache2 by :
sudo service apache2 restart
Then test it out! This is what worked for me, hopefully it works for you.
- 131
If you have other web pages or apps running on the same server, the following information might be useful to separate Nagios as it's own Apache virtual host on a non-standard port (for example 43326 here).
Remove standard config and create Apache virtual host;
sudo cp /etc/apache2/conf.d/nagios.conf /etc/apache2/sites-available/nagios3
sudo rm /etc/apache2/conf.d/nagios.conf
sudo vi /etc/apache2/sites-available/nagios3
To beginning of file add;
Listen 43326
<VirtualHost *:43326>
ServerAdmin webmaster@localhost
DocumentRoot /var/www/nagios3
To the end of the file add;
</VirtualHost>
Enable the new site;
sudo a2ensite nagios3
If you run a firewall (UFW), open the port;
sudo ufw allow 43326
Restart Apache
- 485
