I am having difficulties getting Ubuntu installed on my laptop and I have tried a few different ways of going about this as suggested on the disk. They include a direct install, install within windows and install helper. None of these worked and I do not like or want Windows on my laptop. How can I get rid of Windows and get Ubuntu to install on my computer?
NOTE: Autorun does not work on this laptop for some reason and I am thinking that this may be part of the issue. Please help if you can. Thank you in advance.
~~~UBUNTU INSTALL SOURCE: Disc: Ubuntu 10.04 LTS Desktop Edition
~~~LAPTOP COMPUTER INFORMATION: OS: Windows 8 (Current) System: 2.7 Windows Experience Index Processor: AMD C-60 APU with Radeon(tm) HD Graphics 1.00 GHz Installed Memory (RAM): 4.00 (3.69 GB Useable) System Type: 64-bit Operating System, x64-based processor Pen and Touch: No Pen or Touch is available for display.
~~~ERROR MESSAGE:
Windows Boot Manager
Windows failed to start. A recent hardware or software change might be the cause.
To fix the problem:
  1. Insert your Windows installation disc and restart your computer.
  2. Choose your language settings, and then click "Next."
  3. Click "repair your computer."
If you don't have this disc, contact your system administrator or computer manufacturer
for assistance.
  File: \Ubuntu\winboot\wubildr.mbr
  Status: 0xc0000007b
  Info: The application or operating system couldn't be loaded because a required
        file is missing or contains errors.
karel
  • 122,292
  • 133
  • 301
  • 332
5 Answers5
Well, insert your disk, then shutdown your computer. Then reboot and when you see the boot screen with the Asus logo press the button available for you to be able to boot into the CD (should be "Esc" for Asus Computers), then select the cd drive. You should then be able to go through the instalation. Make sure you select "Remove Windows 8 and install Ubuntu" when installing.
smartboyhw
  • 1,235
You can format the disc in which you have windows installed if you dont have any important data..
IF you have USB drive
Make a live cd of one of the tools given below
  • Hirens boot
  • Acronics
  • Ubuntu (it self)
Run from usb and delete/format the partition (TO RUN FROM USB go to BIOS and change the boot squence) create new partition and install UBUNTU try this if its works.
Even I brought a new Lap from HP and its pre-loaded with windows 8. I tried to install 32bit ubuntu 10.04 with bootable cd which I used to install in my windows 7 PC. I got the same error. I have tried changing the boot order and disabling the feature called secure boot. Still it didn't worked. After a lot of research I found in ubuntu forum that only ubuntu 12 and above can be used to install side by side in windows 8. Because windows 8 has some new setting which prevents the user to install any other OS side by side or even replacing windows 8, and only ubuntu 12 and higher version is compatible with this feature. Even in youtube you won't find a tutorial which explains how to install ubuntu 10.04 in windows 8 pc. It has only ubuntu 12 and above OS tutorial.
I am in the same situation. I must use a Texas Instruments SDK that will only run on Ubuntu 10.04. I tried using Ubuntu as a guest in Virtualbox running on a Windows 7 host, but was having trouble getting hardware (SD Card) to work properly. Decided to buy a new cheap laptop to dual boot Windows or Ubuntu 10.04. New laptop came with Windows 8. I am going to remove Windows 8 and install Ubuntu 10.04 as the sole OS.
Bilhew
The version of Ubuntu you are trying to install is very outdated use the following Ubuntu 13.10 32 bit version to install on your computer:
Thank you | Ubuntu
Just install from CD or USB and if you can clean install it would be the best option as you have problems with erasing windows boot and you have a very old Ubuntu OS, hope it helps.
blade19899
  • 26,994
Brask
  • 1,588
