Apparently you didn't install drivers for your dGPU (your Radeon), here is what you have to do:
- You have to download the following packages:
sudo apt-get install build-essential cdbs fakeroot dh-make debhelper debconf libstdc++6
sudo apt-get install dkms libqtgui4 wget execstack libelfg0 dh-modaliases
sudo apt-get install linux-headers-generic xserver-xorg-core libgcc1
- If you're using a 64bit system, addditionally install these packages as well
sudo apt-get install ia32-libs lib32gcc1 libc6-i386
cd /usr ; sudo ln -svT lib /usr/lib64
- Download and install drivers
cd ~/; mkdir catalyst12.10; cd catalyst12.10/
wget http://www2.ati.com/drivers/linux/amd-driver-installer-catalyst-12.10-x86.x86_64.zip
chmod +x amd-driver-installer-12-10-x86.x86_64.run
sudo sh ./amd-driver-installer-12-4-x86.x86_64.run --buildpkg Ubuntu/precise
sudo dpkg -i fglrx*.deb
sudo aticonfig --initial -f
If you are having problems with switching to your iGPU and Unity3D, you may have to change the /etc/X11/Xsession.d/10fglrx with root
gksu gedit /etc/X11/Xsession.d/10fglrx
If you are using a 32 bit system, the file has to look like this:
LIBGL_DRIVERS_PATH=/usr/lib/fglrx/dri
if [uname -m= 'x86_64' ]; then
if [ -d /usr/lib32/fglrx/dri ]; then
LIBGL_DRIVERS_PATH=${LIBGL_DRIVERS_PATH}:/usr/lib32/fglrx/dri:/usr/lib32/dri
if [ ! -z $LD_LIBRARY_PATH ]; then
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:
fi
LD_LIBRARY_PATH=${LD_LIBRARY_PATH}/usr/lib32
export LD_LIBRARY_PATH
fi
fi
export LIBGL_DRIVERS_PATH
If you are using a 64bit system, like this:
LIBGL_DRIVERS_PATH=${LIBGL_DRIVERS_PATH}:/usr/lib32/fglrx/dri:/usr/lib/x86_64-linux-gnu/dri
fi
fi
fi
