First I had this problem, I couldn't get the login screen it brought me to tty so I installed other drivers and did apt-get -f install
And now I can get to Ubuntu but its very slow and games lag alot right at the menu.
The driver is nvidia-experimental-304.
Now I want to install an older driver that will work good.
Can anyone help? Thanks
Edit:  When I try to install nvidia-current-updates it says this
admin@blackhat:~$ sudo apt-get install nvidia-current-updates
Reading package lists... Done
Building dependency tree
 nvidia-current-updates : Depends: xorg-video-abi-11
                          Recommends: nvidia-settings-updates
